Old 08-24-2005, 10:51 PM   #721
spenzalii's Avatar
Send a message via AIM to spenzalii
Originally Posted by CurveTracer
The problem for my CD3's was the width of the chassis opening beneath the engine flywheel. The starter wheel would contact the edges of the car chassis while touching the flywheel. I ground the edges down with a dremel tool.
Good idea. Quite a few people do this to keep from grinding the starter wheel to bits.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 08-25-2005, 12:43 AM   #722
Originally Posted by masterwebber
Ok, thanks!
But on some cd3 cars, i see an sort of an battery box?
An black case.
And if 1 buy so an 5xAAA battery pack, can i install him with screws?
Couse there are a lot of screwholes in the radio plate
I installed it like this:
http://mike.dynamic-ict.nl/Pics/auto/batterij.jpg
no no, don't install like that. Battery fits UNDER where you have that pack. You didn't throw the plastic battery retainer away did you? See the empty spot behind the receiver (sitting under the flat bit of carbon behind receiver box), the battery goes in there. The image I posted of my charge port is with the battery installed. Thats why you use a AAA pack so it fits. Your CG will be much lower when you put the correct battery in the correct place
au_Nightmare is offline   Reply With Quote
Old 08-25-2005, 06:54 AM   #723
masterwebber's Avatar
Ok, but i did never got an 'Plastic battery retainer'
You mean this? --> http://mike.dynamic-ict.nl/Pics/auto/batterij2.jpg
I've only the radio box, my receiver is in it.
Can i buy that part? You know the number of that part?
masterwebber is offline   Reply With Quote
Old 08-25-2005, 01:37 PM   #724
Yes thats the part. You should have one? All CD3 kits (and upgrate kits) should have them.
HN part number is LCD02 (OFNA # will be different)
photo of the tree. It's the top left part.
And stop using photos of my dirty CD3 after the enduro <grin> eheheh
Old 08-25-2005, 02:11 PM   #725
Thank you so much!
I'll buy the parts as fast as i can!
Old 08-25-2005, 07:02 PM   #726
CurveTracer's Avatar
Roll Center??
Is this parameter changeable on the CD3?
If so, how does it affect the handling and traction?
How do we change it.
CurveTracer is offline   Reply With Quote
Old 08-26-2005, 12:57 AM   #727
is what parameter changeable ?
Old 08-26-2005, 08:48 PM   #728
spenzalii's Avatar
All the more reason to clean the car BEFORE taking the picture, my friend! I'll post some of my ride before and after the charity race in 2 weeks.
Old 08-26-2005, 09:40 PM   #729
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Spen what are the dates of the charity race? I've got some motor problems to solve but I may get a new motor before then anyway. Might push the whip up there . 280 for driving school what a rip off, , I start next monday .
nsxshogun is offline   Reply With Quote
Old 08-27-2005, 12:40 PM   #730
I got the part en it fits perfectly!
Now i've the battery (5x AAA) pack in order
Old 08-27-2005, 08:33 PM   #731
spenzalii's Avatar
http://www.hobbyworks.com/default.cf.../hs/Home/ID/69
There's the info on the charity race. What's wrong with the engines?
Old 08-30-2005, 06:18 PM   #732
Registered User
xrcbuggy's Avatar
Need a better front CVA or universall, any Idea? Please charm in.
xrcbuggy is offline   Reply With Quote
Old 08-31-2005, 12:32 AM   #733
Are you using the old old silver ones (non captured pin), the old silver ones (captured pin) or the black ones?
Old 08-31-2005, 04:47 PM   #734
Registered User
xrcbuggy's Avatar
I am using the Black one & they are very soft, one hit & they bend like butter.
Old 09-04-2005, 06:21 AM   #735
Default Gear ratio and combination
Hi guys, would anyone be able to tell me the gear ratio for the cd3? Is it the same if using either 1.0 or 0.8 pitch gears. Also, what's your gear combination for a track with lots of tight turns and 1 straight of about 100-150 ft? Thanks for your help
madcat prime is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
