Ofna Cd-3
#586
Re: JLR
Originally posted by kevink2
Hey, who's that hunky guy in the new CD3 ads in all the mags!?
Congrats Jeff, really nice 2 pager, wow!
Congrats on the new ad Mr. Linoo.
#587
Re: Re: JLR
Originally posted by C Verano
The hunky mad looking guy.
#589
Quick question. What's the weight of the shock oil that comes with the cd3 pro kit in the U.S ? and spring rate ?
thanks
thanks
#591
Re: diff oil where?
Originally posted by madcat prime
Can you please help me as to where I should put the diff oil? It doesn't say in the manual (diff assembly has grease, what type?). The brand and the weight of the oil you use, front and rear would be handy. Thanks in advance
#595
Hey Guys!
Have just finished reading the thread. The CD3 looks to have been very succesfull in the States. Previously i have owned both a NTC3 and a FW05-R, both cars were very good. I have been tossing up with idea of purchasing another NTC3, but having to go out an purchase Imperial hex drivers is a pain in the arse. And parts for Team Associated are not easy to come by in Australia. My main track here is concrete, and as a result will need to run on rubber tyres. Has anyone run a CD3 on rubbers? Also from reading the thread i think the CD3 Pro comes with a front one way if i am not mistaken, can someone please give me a detailed part listing of everything needed to build a front diff...
Oh, Would the TMagic X5 starter box work on with the CD3?
H-O
H-O
#596
Hi Hooked on.
Whatever starter box you used for your FW05 and NTC3 should work. I have used the same box for my 1/8 buggy, LD3 (same layout as NTC3) and the CD3 (layout = FW05).
For front (or rear) diff, something like this: (part # - HN-xxx) - double check #'s wont you
1 of LS04 6 Gears Diff (12T x2, 10Tx4)
1 of L03 LD3 Cap Joint for Diff (comes with 2)
1 of L01 LD3 Gear Case
1 of L31 LD3 Diff. Gaskets x 3
1 of L05 LD3 Bevel Gear 40T
or
1 of LS02B CNC Steel Bevel Gear (recommended)
You will also need: (sorry dont have part #'s on me)
10x15 bearings x2
2.5mm E-clip x2
5x10 washer/shim x2
5x8 o-ring x2
M2x6 (or M2x8 I think?) flat head screws x4
You can Download the CD3 RTR manual at
http://www.ofna.com/pdf/cd3-rtr.pdf
or the LD3 pro manual at
http://www.ofna.com/pdf/ld3-pro.pdf
But part numbers are wrong for us outside the USA. http://www.hongnor.com/ have a listing of most the parts.
I run my LD3/CD3 on rubbers at one track, its only small but seems to go fine.
BTW while your spending money think about the alloy sway bar holders and lower arm mounts
So you liked the FW05? Few mates have them - Didn't seem to impressed with the soft crown gears compared to my cheaper kit with tough CNC gears.
or
10x15 bearings x2
2.5mm E-clip x2
5x10 washer/shim x2
5x8 o-ring x2
#597
Originally posted by au_Nightmare
Hi Hooked on.
or
10x15 bearings x2
2.5mm E-clip x2
5x10 washer/shim x2
5x8 o-ring x2
Hi Hooked on.
or
10x15 bearings x2
2.5mm E-clip x2
5x10 washer/shim x2
5x8 o-ring x2
Thanks for your response... I did like the FW05, i had to upgrade the crown gears to the steel ones. I had a bit of a look at the online stores in HK (RCModel & RC-Mushroom) and even Radio Models in Perth, none of them seem to have a lot listed for the CD3. Is there any better places?
One question regarding the diff etc, if i bought 2 x Pro spec CD3's could i use the parts from the second rear diff to build a front diff? Or would there be other parts i would need as well?
Also, is there much in the way of any geometry difference between the CD3 and FW05???
Thanks in advance...
H-O
#598
Hey Hooked on
If you have MSN/ICQ/AIM or YAHOO PM me details so we can talk - well type..
Yes 2 kits work well, the rear diff can go in the front + u get all the spares. When I first got my LD3 I got 2 kits just so I am not in the position where I drove hours to race then a $5 part ruin my day
#599
Hey Hooked on
Hey Hooked on
h-o
