Old 02-01-2005, 12:54 AM   #511
MCRUZ's Avatar
Smile
YUP! See you guys there. Be there tues, wen. to practice.
MCRUZ is offline   Reply With Quote
Old 02-01-2005, 06:32 AM   #512
Greg M's Avatar
My CD3 also spins out all the time, but its runnung a gear diff in front. In LD3 form with the front one way it was great, but all the locals with other brands of cars run gear diffs so when I did my conversion I ran the gear diff instead of buying a one way. Car has 6 gear diffs front and rear, both with 120,000wt oil. Any ideas on the spinning out?
Greg M is offline   Reply With Quote
Old 02-01-2005, 01:11 PM   #513
spenzalii's Avatar
Send a message via AIM to spenzalii
Default Set up Sheets
Anybody have any good base line settings for the CD3? I'll be getting mine this month (already stocking up on tires) but have no clue on a good setting for it.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-01-2005, 01:33 PM   #514
Greg M - I have only run a one-way but from my buggy days you have to run a lot thinner oil in the rear - maybe the diff/diff guys can help
spenzalii - I kinda treat mine like the LD3 - the only real problem I had was being really unstable on RH corners - After race day when I looked found when I screw pivot ball washer in the front hub I must of pinched it cause it came loose and camber was floating from like -2 to +4
If you go back in this thread there are a few setups..
au_Nightmare is offline   Reply With Quote
Old 02-01-2005, 08:32 PM   #515
spenzalii's Avatar
Greg, check the diffs to see if they're binding up. My rear diff wasn't shimmed right (I suppose) and would bind up from time to time, causing a spin out of the corner if I even looked at the throttle.
Old 02-01-2005, 11:34 PM   #516
Greg M's Avatar
what I've found is the screws for the rear diff case have stripped and so the diff has emptied itself of oil. With no oil its pretty much locked. Wish I had of found this earlier, such a simple problem.
Thanks for the help guys
Old 02-01-2005, 11:46 PM   #517
Nice work Detective Spenzalii
Greg, if you can - get some good quality machine screws (M2 x 6), that's what I'm using.
Old 02-02-2005, 07:41 AM   #518
spenzalii's Avatar
I try, I try
I only know because my diff did teh exact same thing last season. Very annoying. I just bought a new diff (only $20, couldn't pass it up) and will try to find some machine screws. Only catch is they're not the easiest thing to find...
Old 02-02-2005, 12:50 PM   #519
ah ok, when my diff did that it just turned into a FWD car but I was amazed the crown gears survived ! very good material!!!
Old 02-02-2005, 01:00 PM   #520
spenzalii's Avatar
Mine were toast. It was so annoying, because it was some-timy. Some corners it's fine. Others I'm doing a 180 into traffic. I did manage to find a spot selling 2x6 screws and will pick up a few for the upcoming build.
OK, now I need an engine. Any suggestions? And is the CD3 any quicker than the LD3? I remember having to fight for some low end with the car, even running a 15/21 clutch bell.
Old 02-02-2005, 01:20 PM   #521
Same car different layout. The better non-snail exhaust system should help with power though I asume (I am running Kyosho 5.2 exhaust but you have plenty of options)
RE: engines, I like the STS Dragon engines
Or maybe -
RD/Richey Racing Engine (STS makes engine but I believe to Motormans specs - something like that)
Old 02-02-2005, 01:26 PM   #522
spenzalii's Avatar
Default Saw those
They were the next choice. Someone had a X12 for $200, but jacked the price up a bit too soon for me, so that was out
Old 02-02-2005, 01:39 PM   #523
http://www.rc-mushroom.com/
STS engines on sale ATM... I'm so tempted to buy one but I dont need it - D5 still going well and I already have a D3R waiting for D5 to die.........
Old 02-03-2005, 07:40 AM   #524
spenzalii's Avatar
You weren't kidding about that sale. The price on these things is great. A D5R or D3R under $150? I wonder how they compare to the RDLogic version. At that price, I may just get one this month anyway
Old 02-03-2005, 04:06 PM   #525
TexasRacer's Avatar
Send a message via AIM to TexasRacer
I have my Ofna CD-3 pro for sale call me if interested 512-922-9654 Thanks!
TexasRacer is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
