Old 10-15-2004, 01:24 AM   #271
kevink2's Avatar
Originally posted by C Verano
A picture taken by Mike Myers of Darin Ishitani's car with Alberto Picco fueling it at the worlds. The body was painted by OFNA driver Kevin Kubota, Mr. Kar Sikk Paintwerks.
kevink2 is offline   Reply With Quote
Old 10-15-2004, 01:53 PM   #272
Ron C.'s Avatar
That's my Boy Darin !!!
Let's GO... Let's GO.... Lets GO....
You know I got my money on you !
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 10-15-2004, 02:06 PM   #273
Suspended
NICE PAINTWORK...CHOCO
SERPENTFREAK69 is offline   Reply With Quote
Old 10-18-2004, 07:20 PM   #274
Default set-up question
hey guys,
I got the CD3 pro conversion w/ graphite shock towers,
I'm running:
front:
-120wght diff oil
-0 deg ALU lower arm holders
-0 toe
-camber 2 deg
-shock 50 wght oil, 2nd to inner most hole shock/tower, middle hole/( Lo arm), springs blue
front bar: 45deg
-Upper arm mount, low inner hole (tower)
Rear:
-50wght diff oil
- neg2 deg toe
-3 deg camber
-shock 50 wght oil, last outer hole(tower), middle hole(Lo arm), spings copper
rear bar flat
upper arm low inner hole (tower
Motor:
STS dragon
Gears:
stock(standard)
Wheels:
40 shore all round
I got great stearing, but real loose in the rear. Especially accelerating out of corners. These are the settings I got after messing with shock oil and rear shock position (moved them out from the second hole- in(1) to out(4)- )
Anything I'm doing wrong, any ideas on what to do to get better traction for rear?
thanks,
havy
havy is offline   Reply With Quote
Old 10-18-2004, 07:51 PM   #275
kevink2's Avatar
Default Re: set-up question
Originally posted by havy
hey guys,
I'm running:
front:
-120wght diff oil
-0 toe
-camber 2 deg
front bar: 45deg
Rear:
-50wght diff oil
- neg2 deg toe
-3 deg camber
rear bar flat
Motor:
STS dragon
Gears:
stock(standard)
Wheels:
40 shore all round
thanks,
havy
The easiest thing to try would be to go to 42 front or 37 rear, but beyond that maybe try more positive front toe, like 1.5+, or maybe laydown the front shocks some more, and/or soften rear end. BTW Which shock pistons are you using? Is the diff too stiff for the conditions?
Old 10-18-2004, 08:10 PM   #276
Man, Ihaven't checked the pistons in so long, can't remember, were on my LD3 before (somthing I have to look into)
Front diff actually was looser, I added some more oil and it improved (120). Icould go softer in the rear, or go w/ 4 gear instead of 6 in rear diff.
Are the copper softer than the blue? Or do I got that backwards? That may be the little tuning I need.
It just does't accelerate out of turns that well, just need it to hold a little more. I've run 37's down here,but they wear too fast, sometimes chunk, but I like the way the front steers so don't want to mess w/ that if I don't have to.
havy
Old 10-18-2004, 09:06 PM   #277
C Verano's Avatar
havy
Go with the 4 gear diff in the rear...
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 10-19-2004, 12:02 AM   #278
Team-RTR's Avatar
havy i had the same issues with my car.. there was one hopup i neede to fix all my problems.. its called a V1RRR in all seriousness try moving up to red front springs coz copper is alot stiffer then red, that could be why you rear end is taily.. i also found that my LD3 didnt like alot of steering dialed into it. try dailing out some steering, it makes the car more driveable
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 10-19-2004, 02:30 AM   #279
kevink2's Avatar
Are the copper softer than the blue? Or do I got that backwards? That may be the little tuning I need. Thanks
havy
Yes, the blue are softer than the copper. One quick tip, if you're unsure and comparing spring rates just place them together between your fingers or on a flat surface and compress. Obviously then, the softer spring will compress faster than the harder spring.
Old 10-19-2004, 02:43 AM   #280
oldnitro's Avatar
havy
I have just got a CD3 Pro(not the conversion)
I dont know what your track is but the track i run on here in oz is high speed (flat out 80M with high speed sweeper at the end)with a couple of tight corners.and high traction
It sounds like you might have too much traction on the rear which is pushing it around
The setup used out here might seem strange but give it a go as mine was tail hopping through the sweeper and and a loose rear coming out of corners.
heres my set up which fixed the problem
FRONT
Front one way(some are using a locked diff,stable braking and unreal out of corners)
80wt oil #2 piston springs are 1.6mm(of a GS Vision)
2 deg camber
1 deg toe out
no droop
sway bar soft40 shore tyres
REAR
500,000 wght oil in diff
80wt oil #2 piston Mugen yellow springs
3deg camber
2deg toe in
1mm droop
sway bar hard
42 shore tyres
basically the car has a soft front and hard rear
this might sound strange but guys have been using this setup for a while and it works
Good luck
oldnitro is offline   Reply With Quote
Old 10-19-2004, 02:44 AM   #281
oldnitro's Avatar
oh yea one other thing other CD3 drivers are using red OFNA spring all round
Old 10-19-2004, 03:04 PM   #282
OK guys,
Thanks for the help, lets see what happens.
Oldnitro,
You described my prob pretty well. I'll look into your set-up too, thanks.
I race at 2 diff tracks, one is fast and flowing and the other has some long sweepers and a tight infield (like an oval w/ tight infield).
havy
Old 10-19-2004, 03:12 PM   #283
kevink2's Avatar
Originally posted by oldnitro
havy
FRONT
2 deg camber
1 deg toe out
no droop
REAR
3deg camber
2deg toe in
1mm droop
sway bar hard
42 shore tyres
Good luck
Interesting setup! Thanks! Who makes the 500,000 wt. diff oil?
Old 10-19-2004, 09:22 PM   #284
Bishop's Avatar
Looks like Australia post finally came through for me, I so hate waiting, I ordered it a whole week ago!
And for those wondering (like I was), the HK standard spec 90% CD3 looks to be a slightly better spec than a US base model OFNA CD3, and better kitted out than any of the HK based websites describe.
On the plus side, it came with pro style threaded shocks with yellow springs, dome airfilter etc, basically I think US Pro RTR specs.
The downside for me is the .15 Force engine, I'm not sure it will be race legal in the class I want to run in here.
Also, it looks like there is no instructions either, not a huge issue, but could be annoying to some people.
Bishop is offline   Reply With Quote
Old 10-19-2004, 11:21 PM   #285
Bishop's Avatar
Looks like my kit is missing the spacers required to fit the throttle servo properly, bummer, doing a bit of a strip down at the moment to make sure everything is ok, anyone have some tips on what to check out or adjust on a LD3/CD3?
Edit: oops, my bad, I must have totally misplaced the spacers in my hurry to rip open my package this morning, found them buried under some other parts.
Also realised that there seems to be some alloy steering servo mounts in there as well, at least I think they are servo mounts, can't figure out where else they would be used?, they were in the same small bag with the throttle attachment parts...
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
