Old 09-26-2007, 07:55 PM   #1516
CurveTracer's Avatar
The kit yellow springs which I list as "florescent yellow" when I write notes in my book, work more like a progressive rate spring in my opinion. The initial spring force feels more like 19 lbs of force. They don't seem to be as soft overall as the SNR red springs, ... but i have no way to measure spring force.
After a few mishaps of low batt. power diring a race I hastily moved to a 5 cell hump pack. So this works for both my sons cars (RTR Pro's) and mine (a kit Pro). I hated to cut my top radio plate to fit the battery in, but I never run out of power.
But now I need to trim some weight off the car, so I'll try one of the AAA (1100 mah) packs and see how it holds up.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 09-26-2007, 08:05 PM   #1517
Originally Posted by Marcos.J View Post
it should be here tomorow along with a pro kit, im kepping the regular radio box on the pro kit so i can keep the 5 cell hump pack
I hear that engine increases your heart rate
For gearing I would recommend a minimum of the following combos:
pinion 20/26 and spur 55/49 and 56/50.
I am using pinion 20/26 and spur 56/50 for my Picco and OS TZ engines on short to medium tracks.
Spenz what gear combo are you finally using on your missile.
Old 09-26-2007, 08:43 PM   #1518
spenzalii's Avatar
Send a message via AIM to spenzalii
I'll have to look and see. I think I remember the FDR on both, but I need to look at those gears again
spenzalii is offline   Reply With Quote
Old 09-26-2007, 08:53 PM   #1519
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
what is the kit gearing for the .08 gears?
Old 09-27-2007, 07:54 AM   #1520
spenzalii's Avatar
21/55 1st, 27/49 2nd, giving you an FDR of 6.55 1st, 4.54 2nd.
In comparison, the FDR on the MTX4 is 7.49 1st, 4.97 2nd. A lot of those drivers drop a tooth or so on the spur gear to get a little more top end though.
The hot setup is to use the yellow Mugen clutch shoe and the Mugen super hard spring. It's a good reliable setup for a snappy and responsive clutch.
In looking over the gearing, I may readjust mine once again. I know my first gear is somewhere in the 7 range, which may be too short for the tranny. I'll try a high 6 and see how it goes from there.
Old 09-27-2007, 09:35 AM   #1521
Super Moderator
Marcos.J's Avatar
thanks
Old 09-27-2007, 03:56 PM   #1522
Super Moderator
Marcos.J's Avatar
Originally Posted by 20 SMOKE View Post
the way you drive it wont matter
lol looks who talking
Old 09-27-2007, 03:57 PM   #1523
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
does anybody know what is the lbs rating of the yellow springs?
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-29-2007, 05:28 PM   #1524
Default Must have optional parts
Marcos_J
There are a couple of optional parts that you should consider adding to any CD3.
1. aluminum A-arm mounts for the rear. The plastic ones will not hold up from accidents and will allow the hinge pin to pop out.
2. a wide bumper guard that is almost as wide as the front track width. I have mine narrowed a bit (180 mm) but it protects the front suspension during a hard collision. This will 'reduce' the occurrence of the steering knuckle poping off of the pivot ball when you have an accident.
3. 4mm rear upper link turnbuckles. Lunsford titanium if you can afford it.
4. Use front wheels that have an offset of 1 to 2 mm. The 0 mm offset wheels tend to rum the tie rod ball ends and weaken them.
Old 09-29-2007, 11:49 PM   #1525
Super Moderator
Marcos.J's Avatar
Marcos_J
thanks buddy!! I got a Pro Kit in the mail over the weekend, built it and broke the motor in today!! im going to run it tomorow for the first time. I found some 900mah AAA NiHm batteries today too and built a receiver pack for it ($11.99 at CVS)
Old 09-30-2007, 07:53 AM   #1526
Super Moderator
Marcos.J's Avatar
well ran the car today for the first time, it was really good my set up had alot of steering and was able to carry a lot of corner speed. JL engine was very fast track was a little tight but very happy with the car. Ill post the set up later today.
Old 09-30-2007, 09:29 AM   #1527
Super Moderator
Marcos.J's Avatar
here is the setup
Old 10-01-2007, 04:46 PM   #1528
Spenz,
I installed the Mugen Yellow clutch shoe. Launching seems easier under low traction conditions. I am using the stock Power clutch spring. How much harder is the Mugen (hard) spring? I am assuming that I will need a lot more traction to use it.
Old 10-01-2007, 07:22 PM   #1529
Default Marcos CD3 setup
Hey Marcos_J,
the setup looks like a winner. How is your acceleration with the current gearing? Some of the other CD3 racers are using very low/aggressive gearing with the Red Dot engine.
Actually I miss using the 21/27 , 55/49 combo I like to hear the engine spool up at wide open throttle.
Old 10-02-2007, 06:48 AM   #1530
Super Moderator
Marcos.J's Avatar
Hey Marcos_J,
its seems pretty good , but ill know for sure this sunday
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
