Old 04-15-2010, 06:09 AM   #1
Default rebuilding shocks tips?
any one got any tips?
i ussually spend about half a bottle of oil trying to get the left and right feeling the same and end up with oil all over my hand and just give up..
i can NEVER get the right to feel the same or get the same rebound!
LiL_JaSoN is offline   Reply With Quote
Old 04-15-2010, 12:31 PM   #2
Loveless's Avatar
www.teamxray.com Try this out bro. you have to go through the site a bit, but they have a very informative section on the set up section on shocks, hope this helps.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 04-17-2010, 10:34 AM   #3
I spent an hour searching the site and couldn't find it. Maybe the article was removed...
no hand is offline   Reply With Quote
Old 04-17-2010, 01:47 PM   #4
Trader Rating: 18 (100%+)
Just "google" rebuilding RC shocks
It will pull up quite a few sites.
Ofna has a good video on building shocks.
It is for off-road shocks, but the method is pretty much the same with on-road shocks
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 04-17-2010, 03:54 PM   #5
Team Kamikaze's Avatar
Here is a video that shows you how to properly rebuild a shock, http://www.redrc.net/2009/11/pro-tip...%80%93-part-2/
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-17-2010, 07:02 PM   #6
iv seen about 5 different ways of doing it
re-fill as normal remove bubbles etc!
1. shaft compressed then bladder on & screw on
2. shaft extended then bladder on & screw on
3. same as above 2 but bladder inside cap.
4. shaft compress, bladder on, then extend shaft with bladder on so it sucks in the bladder etc.
thanks iv watched that video
Old 04-18-2010, 02:20 AM   #7
Azizi's Avatar
i try to glue of bladder..
i have great performance.
Azizi is offline   Reply With Quote
Old 04-18-2010, 07:26 AM   #8
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default socks
do you think you can get the shocks exactly 100% the same your kidding your self, just get the shocks to rebound, not too quickly about 5 seconds if its 1or 2 seconds thats too fast. compress the two at the same time and get them close to the same, when you run the car the shocks don't move nearly as far as you think.
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-19-2010, 10:46 AM   #9
i was wondering on what weight mugen shock oil is compairable to there 600 weight oil is it 50 55 weight
infernoman2008 is offline   Reply With Quote
Old 04-19-2010, 11:15 AM   #10
nitrodude's Avatar
Just get a Serpent a Serpent shock building tool, easiest shocks to build.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-19-2010, 07:28 PM   #11
Default shock weight
usually 600 is equal to 60 wt. and 400 is equal to 40 wt and so on
Old 04-22-2010, 08:12 AM   #12
trickd122's Avatar
Well almost, cst rating not that simple. At first there was a calculation floating around that you simply drop the last Zero of the cst rating and it translates to it "in wgt" counter part. That is not true. Also keep in mind ALL oils are NOT equal. That being said...here you go...
No offence PB
http://www.teamxray.com/teamxray/sho...fa3030b0e97044
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 04-25-2010, 11:12 AM   #13
http://www.rcrcr.com/index.php?optio...eral&Itemid=46
found this, i use losi weight and it is saying 40 is = 500.
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 06:52 PM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 04:31 PM
Shock Building tips needed! fishymamba Electric Off-Road 14 08-28-2009 01:09 AM
Lets talk shocks....... srp67 Electric On-Road 10 05-26-2008 10:38 PM
