Need help tuning MT-12 >
Old 05-14-2004, 11:57 AM
Default Need help tuning MT-12
Hey guys,
I've just intalled a new piston/sleeve in my MT-12 and I'm having trouble re-tuning. The main problem is I'm not very familiar with three needle carbs, I'm comfortable with the HS and LS needle, but the mid is screwing with me. Does anyone have the factory settings for this carb? or what are you running?
Thanks a lot guys,
Patrick
P.S- I've just started to lean it out from breaking it in, and I find it's bogging at a little over 3/4 throttle.
Drivrfound is offline
Old 05-14-2004, 01:44 PM
afm
afm's Avatar
Default Re: Need help tuning MT-12
Originally posted by Drivrfound
Hey guys,
Thanks a lot guys,
Patrick
HSN = 5 turns out, then start leaning 1/8th at a time if needed.
LSN = 3 turns out, then lean or open as needed to get at least 30 seconds idle without engine clogin to the point of dying, it should hesitate a little after 30 seconds but not die. To do this, let engine idle then press full throtle for a second or two to clean it out, then check the 30 seconds idle.
Mid Needle = flush with carb body with slot for screwdriver pointing the fuel inlet, then DON'T EVER TOUCH IT AGAIN.
AFM
afm is offline
Old 05-15-2004, 01:07 PM
Thanks a lot, as it turns out I had my adjustments screwed up. I was using the mid as the low and vise-versa...
Thanks again,
Patrick
Old 05-16-2004, 09:53 PM
Default mt12
pwede malaman san ka nakabili ng parts for the mt12?
thanks
gioJahn is offline
Old 05-17-2004, 01:24 PM
Sorry man, I have know idea what you just said...
Patrick
