Old 05-11-2004, 11:58 PM   #61
Nitropimp's Avatar
Pawntoe- thanks for those killer pics.
Nitropimp is offline   Reply With Quote
Old 05-12-2004, 12:33 AM   #62
InitialD's Avatar
Originally posted by kitracer
I will steal some pictures from the HK RC model magazine people. IF they r not too big, I will post them here.
Hey kitracer, how was the race? How did the engine do?
Old 05-12-2004, 02:53 AM   #63
kitracer's Avatar
I went there to test the engine so in general was good. I pre qualify 14th but the gear messed me up .
That 16T first gear is stupid. Never use that 16t on 710 again ( unless you use shitty power engine )
The pitch is too sharp so it will eat the first gear. It was all too late when I found out from suruth and his mechanism why I am having that problem.
The Competition level is high. look forward to the next one.
kitracer is offline   Reply With Quote
Old 05-12-2004, 03:07 AM   #64
I will call it "unperfect"module for that 16T.
No problem when used with 60T, but when using 61T must grind the engine mount hole a bit.
GoldFinger is offline   Reply With Quote
Old 05-12-2004, 04:29 AM   #65
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Originally posted by prawntoe
the sabah guys were there. . . you should be able to see few of them in the pix.
oh great which page is that....there are like tons of picture there
oh well, i guess i have to browse each of them...
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 05-12-2004, 10:41 AM   #66
prawntoe's Avatar
yeah . . it's more interesting if it's just a few pix but alot of pix become quite boring . . especially when the racers don't bring their pretty g/f along . . .
anyway I went there, snapped the pix one by one, render them to size one by one, upload them one by one, relook at them one by one (to see if non of my underwear pictures are in there). . now it's your turn to look for your friends one by one
prawntoe is offline   Reply With Quote
Old 05-12-2004, 07:43 PM   #67
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Default hi
Which engine brand run very powerful?
suntok2 is offline   Reply With Quote
Old 05-12-2004, 08:36 PM   #68
InitialD's Avatar
14th? Maybe I'm wrong but I thought 13th and 14th placing belonged to a Singaporean drivers...
Perhaps your engine was too powerful ! I noticed that you need to mesh them very tightly with the 16T pinion. It will get free after a tank or two. If you mesh them loose, it'll strip. I never had problems with mine. A friend of mine initially had that problem with 16T/61T combo but later found out that the mounting from the aluminum engine mounting to the engine craskcase was not tightened properly.
I also noticed that if you use new set of spurs and pinions, the meshing gets better. If you used new 1st pinion with old 2nd pinion and spurs, you will find that meshing it correctly would make the meshing tight.
Old 05-13-2004, 04:56 AM   #69
kitracer's Avatar
[I also noticed that if you use new set of spurs and pinions, the meshing gets better. If you used new 1st pinion with old 2nd pinion and spurs, you will find that meshing it correctly would make the meshing tight. [/B][/QUOTE]
trust me, there were many expert on the track, setting as well as driving.
16t don't work......unless you are cruising
Old 05-14-2004, 03:52 AM   #70
kitracer's Avatar
Final & qualify position
1 5 MING-HUI CHU 155 45:04.877 16.366
2 3 CHEUNG , CHRISTOPHER 153 45:08.249 16.143
3 6 CHE-HAO HSU 153 45:10.506 16.417
4 9 SAMPUN LOMROSE(ANG) 152 45:13.606 16.662
5 4 DILAKA L.(WOW) 148 45:08.339 16.338
6 7 JI HWAN CHANG 146 45:08.880 16.808
7 8 SAM CHENG (SIN) 145 45:03.412 16.321
8 10 CHARLEE PHUTIYOTIN 134 45:15.125 16.317
9 1 SURUIKARN C. 106 35:44.990 15.730
10 2 SURUTH V. 62 45:00.685 16.044
Old 05-14-2004, 04:32 AM   #71
Sow&Steady's Avatar
Kit, I tried it last night at my indoor track. It works fine, new 16 and new 60.
I also tried 16 and 61 but had too much pickup and I was overshooting. Meshing was slightly tighter.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 05-16-2004, 10:29 PM   #72
jfc_tech's Avatar
i must be cruising then coz im using 60T/16T and mine is still fine. and im using Max MF P5.
Old 05-20-2004, 06:32 PM   #73
Varuth's Avatar
Congrat to SURIKARN...GO FOR IT THAI GUY. I am a Thai guy living in L.A. Will go see Surikarn at Reedy USA. GO FOR IT. GO FOR THE 2nd World Champion!!!!
Varuth is offline   Reply With Quote
Old 05-20-2004, 06:56 PM   #74
Varuth's Avatar
Any has a full nice video clip of Surikarn?
Old 05-20-2004, 09:31 PM   #75
kitracer's Avatar
http://www.rc-magazine.com/modules.p...howgall&gid=88
sorry no vidoe, Just pictures. I think over 500 pictures from the above links.
Enjoy
FEMCA 1/10th and 1/8th Onroad Championship Danny Teh Malaysian R/C Racers 152 09-07-2008 09:49 PM
Femca Malaysian National Championship bulldog1 Malaysian R/C Racers 87 09-06-2008 03:50 AM
2006 FEMCA On Road Championship jeffreylin Nitro On-Road 16 06-05-2006 03:23 AM
2005 FEMCA 1/8th OFF ROAD CHAMPIONSHIP django Electric Off-Road 0 01-24-2005 09:35 AM
2005 FEMCA 1/8th OFF ROAD CHAMPIONSHIP django Australian Racing 0 01-24-2005 09:17 AM
