Old 04-07-2010, 09:19 AM   #1
furbygr's Avatar
Default Schumaher Fusion 28
Hi, to all
Just bought it and i like to known a few things if possible
the manual says to run the car for 2-3 tanks at half throttle before race.
You think this is enough?
Do you know also if the electric drill is necessary for the start?
furbygr is offline   Reply With Quote
Old 04-07-2010, 04:52 PM   #2
Default Break -In At least 4-6 Tanks
Originally Posted by furbygr View Post
Hi, to all
The first two tanks are for lubrication. The piston and sleeve are two tight to be ran at full throttle. I would run the car up to temp then let the engine cool slowly before my next tank. Start tuning for performance at tank 6-8. Pleas use patience with nitro cars the better you tune and break it in the longer it will last and the better it will run.
iflydaily is offline   Reply With Quote
