NOVAROSSI Turbo Glow Plugs - BAD BATCH >
Old 04-19-2004, 01:21 PM
Ron C.'s Avatar
Default NOVAROSSI Turbo Glow Plugs - BAD BATCH
Hi guys,
We have been finding that there are some BAD Batches of
Novarossi Turbo Glow Plugs in the market today.
It's been on a few events where the plugs have just given up
after only a tank of fuel and some even less. When we check
the filament, its not distorted and is actually still shiny and in
perfect spiral form. But it just doesn't illuminate... Very strange.
A couple of weekends ago, one friend went thru 16 glow plugs
during the entire weekend. And I know of a person who actually
went thru 46 glow plugs during the Winternats.
Very rediculous and also EXPENSIVE.
Does anybody else been having the same experience?
Ron C. is offline
Old 04-19-2004, 01:51 PM
Well that explains yesterday
I went through 3 brand new #6 plugs in 3 heats. For the life of me I couldn't figure out why they were giving up. The engine was in tune, with good temps, and the plugs looked beautiful. They just wouldn't glow
tekrsq is offline
Old 04-19-2004, 02:13 PM
Default That figures
Yes, i've also been experiencing that. Not only turbo plugs but standard plugs too. No. 7 to be exact. I had 4 plugs last Saturday's practice which i picked up at me local track. And to make things matter worst, i only had 6 tanks full of practice runs. And if you look at the plugs, it looks fine but when you fire it up again, then it's gone.. WTF is going on!!
manokgt4 is offline
Old 04-19-2004, 02:20 PM
Francis M.'s Avatar
i hope this is temporary just because it is starting to cost a
lot.
Francis M. is offline
Old 04-21-2004, 12:28 AM
Cat Skinner's Avatar
Just got back from Vegas (Speedline 2004) and was wondering what was going on with those plugs, two of us went through about 16 plugs. All would work fine until engine was shut down then some went bad. A few lasted several tanks but would still go bad. We tried lots of stuff before we put the blame on the plugs. Changed the tank, new exhaust line, motor, carb, ect. ------ Finally got different plugs and problem was gone.
Others out there?
Cat Skinner is offline
Old 04-21-2004, 01:42 AM
Same here in Indonesia.
Mostly no.6 turbo.
Seems like they having problem with their new plug body material.
GoldFinger is offline
Old 04-21-2004, 05:06 AM
jfc_tech's Avatar
Mostly no.6 turbo.
no wonder....i thought my engine tuning problem. damn man
yes that no.6 specifically.
jfc_tech is offline
Old 04-21-2004, 09:20 AM
Ron C.'s Avatar
Others out there?
Cat,
That's exactly what happened to us.
We started to put two and two together when we had gone
thru about 11 plugs then ran out of #7s and #8s Turbo Plugs.
So I had no choice but to put on one of my old plugs. Well what
do you know, it lasted 2 entire qualifiers (with warm ups) and
also a few tanks of practice runs after.
Novarossi should fix this problem.
Ron C. is offline
Old 04-21-2004, 09:44 AM
stefan's Avatar
Sounds like a problem with the lower welding spot of the coil.
stefan is offline
Old 04-21-2004, 09:46 AM
NCC
NCC's Avatar
I too was experiencing the same thing. I was actually blowing a plug for every tank of fuel I ran and had never experienced that this kind of crap before. I switched the brand and it went away. We should atleast get something back. This is getting way too expensive.
NCC is offline
Old 04-21-2004, 09:49 AM
Ron C.'s Avatar
I agree Stephan that that is whats happening...
Since the coil seems perfect and shiny from the outside, it
should be the inside connection that is giving up on these
things. (Something we can't see when looking from the outside).
Ron C. is offline
Old 04-21-2004, 01:58 PM
Roger's Avatar
Man, that's why. I went through some NovaRossi plugs for my P5 motor for my buggy at the U.S. Gas Champs. I looked at the filament to see the condition, it looked ok. I ended buying some RB plugs I went through a few of those as well.
Roger is offline
Old 04-21-2004, 02:22 PM
Francis M.'s Avatar
I hope this is sorted out soon because i can't afford to
go through 5 to 10 plugs per weekend.
Old 04-21-2004, 02:42 PM
C Verano's Avatar
I should be getting some plugs soon...I'll let you guys know if the problem goes away.
C Verano is offline
Old 04-21-2004, 05:26 PM
PSI Racing's Avatar
I just got 6 new plugs a couple of weeks ago.
I hope none of them are from that bad batch.
My brother sent them down from Washington state.
Is Novarossi reimbursing us for any bad plugs?
PSI Racing is offline
