Old 04-19-2004, 01:18 PM   #1
Send a message via AIM to goldenboy
Default r40 pulley's ??
everytime i race my side belt comes off, and i think it is because of the pulleys, i want to be able to finish a race with all 4 wheels, intead of two. does anybody know if they have pulley's out there taht are better, maybe have bigger walls?? if you do can you tell me where i can find them.
goldenboy is offline   Reply With Quote
Old 04-19-2004, 01:48 PM   #2
bballer's Avatar
maybe you need more belt tension?
bballer is offline   Reply With Quote
Old 04-19-2004, 04:00 PM   #3
yah, but i have it has low or as tight as it will go, and it still falls off every race.
Old 04-19-2004, 04:08 PM   #4
AMGRacer's Avatar
I have a R40 with normal pulleys and my belt stays on fine. Your belt should not be falling off that easily. Are you running the 22T front pulley or the 23T?
AMGRacer is offline   Reply With Quote
Old 04-19-2004, 04:10 PM   #5
Regional Moderator
Darkseid's Avatar
Maybe its time for a new belt. If you have it all the way down and its still falling off, thats a belt problem, not a pully problem.
If your car is new, then you may want to give HPI a holla and let them know about your problem. If your car isn't new, try a new belt.
Good luck.
TLR 22...Tamiya F104...
Old 04-19-2004, 04:30 PM   #6
Suspended
hudy's Avatar
or maybe you did not put the correct pulley on when u built it
hudy is offline   Reply With Quote
Old 04-19-2004, 04:42 PM   #7
yah my belt is pretty ragged, i will try that
Old 04-19-2004, 04:47 PM   #8
AMGRacer's Avatar
Check the front pulley!! If you have the 22T pulley on the belt is very loose. Put the 23T on if this is the case.
Old 04-19-2004, 05:41 PM   #9
i checked it and it says 22-23, so what does that mean lol, how else would i be able to check with out counting them indivdually
Old 04-19-2004, 05:42 PM   #10
i have the 23t
Old 04-19-2004, 05:53 PM   #11
AMGRacer's Avatar
i have the 23t
OK cool. Well you must have messed up the belt somehow. I think Darkseid is right try a new belt first.
Old 04-19-2004, 06:12 PM   #12
alright... i dont feel like starting a new thread so do you know anywhere that sells titanium pivot balls for the r40, i snapped one of mine right in half a week ago and the rod stayed in the a-arm so iit kinda screwed me that whole day, but if you do that would be great! the size is 7.9x18mm, weird.
Old 04-19-2004, 06:18 PM   #13
AMGRacer's Avatar
There is some info on the R40 thread about this. I have GPM pivotballs in my car, but I am probably not a good example as I dont really crash that hard or often. Some people are suggesting Mugen Pivotballs.
Old 04-19-2004, 06:38 PM   #14
Regional Moderator
Darkseid's Avatar
Good luck...
Mine went from 'new' to 'tensioner all the way down' in a hurry. But it has settled in now.
Old 04-19-2004, 06:43 PM   #15
yah i have heard about the mugen ones, but where i work we sell them for 115$ and that is a lot of money, because it comes with the whole set. is there a place where i can order them single or a least a pack of 2??
