Old 03-19-2002, 06:29 PM   #1
Send a message via AIM to Raytrix
Default .12 JP New RS12Turbo RE Need engine info
I need some info on this RE engine by JP. It's a JP Modify RS12T turbo. Need some specs on it like HP,RPM, and reliablity. Anybody seen this engine run before compared to the MT 12 , Novamega, and RB 3 port X12?
Raytrix is offline   Reply With Quote
Old 03-19-2002, 07:03 PM   #2
AMGRacer's Avatar
I have a RS12 non-turbo which is a nice engine. Gets out performed (could be me!!) by MT12 engines in the low to mid range. Requires a lot more tuning than the CX12 and MT12 engines (I mean chassis tuning).
AMGRacer is offline   Reply With Quote
Old 03-19-2002, 10:26 PM   #3
Motorman's Avatar
AMG
have you run your RTU yet?
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 03-19-2002, 10:32 PM   #4
AMGRacer's Avatar
Originally posted by Motorman
AMG
This weekend is the big racing debut I was gonna run it earlier but I was playing with my old RS12 trying to get it right. Still no success.
I have shimmed the RTU, just wondering what plug to use. I have a Novarossi C4S in there now. Also I am using 20% nitro with 9% caster and 3% synth. Hope thats an OK combo.
Old 03-19-2002, 11:23 PM   #5
Motorman's Avatar
Use a number 9 plug preferrably MC 9 or dynamite 9 (They are the same) Or an alternative is a number 8 novarossi or RB. That engine will kill anything colder than that due to combustion turbulence. The 9 will give you more off the corner torque. Be sure not to overlean the low end. It should struggle to shift the first 2 laps of warm up (the low end needs to be that rich) The top should be around 4 1/2 and the bottom 3 1/2 from closed. After the five minute warm up the engine should be 220 to 240. It will come on at the 7 minute mark and should come off the track 245 to 265. Low speed in many cases will have more of an effect on engine temp than the top.
Any one use the engine or have any info on it? Dreddlox Onroad Nitro Engine Zone 0 01-17-2006 06:45 AM
any info on the picco xp .12 rear exhaust engine ? mrgsr Onroad Nitro Engine Zone 5 03-20-2005 03:33 PM
Info on RB engine deanspoors Nitro On-Road 8 02-01-2003 01:22 AM
Need info on swapping Novarossi engine parts rod_b Nitro On-Road 4 12-27-2002 06:09 PM
MT 12 Engine info. ProRacer03 Nitro On-Road 27 04-12-2002 03:41 PM
