Old 03-30-2010, 05:43 PM   #1
Trader Rating: 20 (100%+)
Default tire compound question
Hey all...new to 1/8 onroad and looking to get into it. I was browsing tire selection and noticed that each tire is followed by a corresponding #. My question is the higher the # the softer or harder the compound..
I will be p-lot racing mostly w/friends running a MRX-3 or MRX-4..so which compound would you all recommend..
thanks!
magman123 is offline   Reply With Quote
Old 03-30-2010, 06:15 PM   #2
Trader Rating: 18 (100%+)
The higher the shore number, the hader the tire compound.
33 shore are softer than 40
Its kind of difficult to say what shore you will need without knowing the condition of the surface.
Smooth, course, it is a little difficult to say.
Usually a safe bet would be some where around 37 shore<not the softest, not the hardest>.
Soft tires will wear out faster than the harder shore tires
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 03-30-2010, 07:53 PM   #3
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
thanks!
When I raced 8th onroad a while back we always used 40 shore front and 37 rear. Sometimes I ran the same shore all around. After a while when the tires dried out I hosed them with WD40 and used a rag to soak up the excess. Believe it or not this does help restore traction. Don't forget to use the 7mm split between the front and rear tires. There was also a trick to use a different pulley up front if you don't have access to a tire truer however I forgot how many teeth difference between stock.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-04-2010, 10:21 AM   #4
thanks for the replies guys...the surfaces will be pretty coarse. Only one surface is fairly smooth.
So, I am thinking of 40 front and 35-37 rear? sound ok?
Losi Tire Compound Order?? Frank L Nitro Off-Road 6 08-09-2009 07:30 AM
Tire Compound TQ ?? Armedforces Electric On-Road 10 04-22-2008 02:33 PM
Tire selection question. racenut123 Electric Off-Road 30 11-27-2007 09:25 PM
