Old 03-29-2010, 03:33 PM   #1
*BBB*'s Avatar
Default OS .18tz or Traxxas 3.3?
which of these two is stronger? My friend has the 3.3 but i hope i have somthing in store for him with the TZ! I was more confident until i found out the 3.3 is .2 cu. in.
thanks all
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 03-29-2010, 11:56 PM   #2
casterdriver's Avatar
a properly tuned 3.3 (nice lean and dam near 300 degrees)is just as strong as an 18tz, actually stronger on the top end by far, only problem is you get about 1/2-1 gallon of race time after break-in before the bearings die. If you wanna play the bearing game every other weekend(ebay case/bearings is like 10 bux) I would use the 3.3 if you dont wanna play the game use the 18TZ btw the factory guys run 3.3's in the revos..........to do a 18tz in a revo the right way and use the factory clutch/flywheel/clutchbell and not have to hack the crank is to put a 18TM crank in the tz....... its a bolt-in then. BTDT bought the t-shirt a few times......
Mugen MBX7/WERKS CRE-B6,Stock B6,Stock B2/Werks 2013,2057,2058
RC10GT2-FT, Dynamite Platinum .12
VP-Racing Powermaster 20% and 30% Race Fuel
Official NON-EXPERT
casterdriver is offline   Reply With Quote
Old 03-30-2010, 12:06 AM   #3
*BBB*'s Avatar
What does hack the crank mean? Thing is my buddy has 3.3 and i have the .18tz..
Old 03-30-2010, 08:00 AM   #4
The .18tz have an SG shaft which isn't the same shaft that the TRX 3.3 has. Some people take out the .18tz shaft and put the .18TM shaft so they can use their stock flywheel, clutch, and clutch bell. You get an Ofna shim kit and that will work also.
jclay is offline   Reply With Quote
Old 03-30-2010, 08:12 PM   #5
I agree 100% that a poperly modified/tuned 3.3 will run faster than a .18 TZ will. I have both and they are equally modded by RBmods.net and the 3.3 walks the walk over my .18 TZ. I also had ceramic bearings put in the 3.3 since bearing failures are a problem with the stock ones. I have a small video of my 3.3 in an OFNA CD3 here.
http://www.youtube.com/watch?v=1u7gtgyvR5c
Brent Davis is offline   Reply With Quote
Old 03-30-2010, 08:43 PM   #6
*BBB*'s Avatar
ahh.. i was hoping my tcs w .18tz and racing pipe would beat his stock 4tec 3.3.. How much advantage would using a good fuel be then?
Old 03-31-2010, 08:22 PM   #7
ALLSPEED's Avatar
The 3.3 is a throw away engine. By no means is the 3.3 better then the TZ. One guy said he got his 3.3 modded by RB. Did you get his piston and rod with the mod? I have had one 3.3 and three TZ's. The TZ is by far the strongest small block on the market. They are about the same down low but the tz has way more USEABLE rpm. Just keep this in mind. A 3.3 has to be modded and ceramic bearings must be installed. that's just to run with a stock tz.
Kyosho evolva M3 EVO O.S. .21xzr? Xray NT1 murnan modded nova,Xray T3,AE T5, sc5m, b44.3,Tekno sc
Mugen 1/8 off road.Tekin esc's, smc batts, team powers motors a winning combination
ALLSPEED is offline   Reply With Quote
Old 03-31-2010, 08:41 PM   #8
Suspended
You do not have to mod the crank to fit the TZ on the Revo. If you do that means ur chassis is bent. All you need is the proper flywheel set up.
3.3 out runs a TZ??? the TZ must be running rich and geared for bottom end. and if the 3.3 does happen to win under those circumstances itll prolly take a dump after the race cuz we all know how lean the 3.3 like to run. factory guys run 3.3's because thats what their sponsored to do so thats a no brainer. you dont see anyone buying a 3.3 to put on ANY other chassis besides a traxxas one. and if they do theyll be sadly disappointed.
RB Mods isnt a true 3.3.....its a 3.3 case w/his fabricated parts in it
4tec is a piece of crap, IMO. youll never see one on the track. its a parking lot basher.......1:1 cars beware of the barrell rolling rc in the lot AKA the 4tec
Jusleanit is offline   Reply With Quote
Old 04-01-2010, 08:28 AM   #9
*BBB*'s Avatar
lol.. yea i talked to a engine mod guy and he said you can get ALOT more power out of the 18tz than the 3.3
Old 04-01-2010, 09:23 AM   #10
BBB, Brent Davis is a racing guru. His RB modified 3.3 is unique. He is a master of street racing. Everything he has is extreme and super fast.
nitrohead5300 is offline   Reply With Quote
Old 04-01-2010, 09:36 AM   #11
Suspended
ur 100% correct. it is UNIQUE, i reapeat.............a Traxxas 3.3 block w/ RB internals
Old 04-01-2010, 07:57 PM   #12
YUP!!!!
Old 04-02-2010, 06:40 PM   #13
*BBB*'s Avatar
Yea i talked to a mod guy and he was really confident you could get alot more power out of the .18tz
Old 04-02-2010, 07:44 PM   #14
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
ok who would mod 3.3,imo is waste of money.most of traxxas products are geares high mainly for bashing.99.5% of the people dont race a 4tech, l maybe wrong,most tc3 owners with a 18tz start bashing then head to the track to race ...18tz has consistant pwerband where the 3.3 don't ..just my opinion
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 04-02-2010, 08:13 PM   #15
ALLSPEED's Avatar
You would be surprised. Traxxas has a loyal following. Idk why any one would get a traxxas engine modded. A 3.3 is not in the same league as the TZ. In order to get the 3.3 to come close you have to replace all moving parts with after market parts and then the port and polish.
3.3 EB Mod OS 18TZ Revo with hop-ups plus extra parts big igg R/C Items: For Sale/Trade 19 09-29-2008 12:54 PM
GOING OUT OF RC CRT RTR OS JATO REVO 3.3 (RTR) Os_powerd_jato R/C Items: For Sale/Trade 6 01-03-2007 08:15 PM
