Running Problems
Running Problems
After a few mins running and also frok start the car does idle smooth.
It will go up and down etc. And was thinkin that this proberbly an air leak. Im thinking this is the primer on the tank as i know many people that have had problems with the primer.
Im running an HPI RS4 3.
Shall i go ahead and remove primer and block hoel and if its ok, get a new primerless tank.
I pulled my primer out of mine and put a screw in it with some shoe goo. Then I replaced the tank later. I also seal the engine to make sure I wasn't getting any air in around the back plate and carb. Might also want to check to see if you head is on tight along with your glow plug.
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
AIR LEAK oh... AIR LEAK
go here:
click me! click me! click me! aaaaaaaahhhhhhhhh
u will be amazed what this artcile tells you... all about air leaks... especially from engine and tanks.
they even say... NEW ENGINE also sometimes have air leaks... so right after you buy the new engine... please make sure to do what the article suggest....
thanks to IntialID who gave this link to me.
mop
mop
