Old 04-13-2004, 04:50 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Default Extended Return Pressure Tubing
What advantages does this have.
I see soem cars have then long and cable tied up, and others just keep them short.
doublest is offline   Reply With Quote
Old 04-13-2004, 05:51 PM   #2
mckrooz's Avatar
Send a message via AIM to mckrooz
One thing I noticed with a long pressure line was that it made my engine idle better.
mckrooz is offline   Reply With Quote
Old 04-13-2004, 07:28 PM   #3
Nitropimp's Avatar
Manticore show'd his car with his extended return pressure tubing...
take a look
Nitropimp is offline   Reply With Quote
Old 04-13-2004, 07:52 PM   #4
sbmon's Avatar
I did the same thing with mine too
but i did it on the fuel line
I was having trouble with a 5 port making time (5minute qualifyers) but now she runs 30 minute mains with only 1 pit stop!
sbmon is offline   Reply With Quote
Old 04-13-2004, 08:17 PM   #5
fmolzer's Avatar
The theory with long pressure line is that it will soften the pressure wave from each combustion cycle (since the tube will flex (expand) more if it is longer, thus not foaming the fuel and evening the pressure waves out a little. In reality, it probably adds more weight than anything. I usually just use a line that is about 12 cm long or so. Just enough to where you can connect it without any sharp bends. This works just fine and is how most factory guys run. Longer fuel line will give you the advantage that you will run a little longer, and if your car goes belly up your engine will run longer before stalling, but it typically also puts you above the 75 cc limit in sanctioned racing, and it adds resistance to the fuel supply. (try sucking on a straw that is 5 feet long rather than one that is 7-8 inches and you know what I mean).
fmolzer is offline   Reply With Quote
Old 04-13-2004, 09:11 PM   #6
mckrooz's Avatar
So true.
Old 04-14-2004, 02:03 AM   #7
Send a message via ICQ to V-One S
Ahh the pressure line, from exhaust to tank can be any length last time i checked...
A long pressure line is good for high speed, fast tracks, where you want the amount of fuel supply to be basically kept constant...
Whereas, a short line is for shorter twistier tracks, so the amount of pressure fluctuates quicker...
A long fuel line on a short twisty track will really starve the engine... running from a slow corner onto a high speed straight
V-One S is offline   Reply With Quote
Old 04-14-2004, 03:47 AM   #8
doublest's Avatar
Arrow
Thanks for the help everyone.
I'll have a go at longer and compre with shorter lines.
Old 04-15-2004, 04:21 PM   #9
mckrooz's Avatar
I've noticed that running a long fuel line (about 8") really causes the motor to be really hard to tune and the performance goes way down. As soon as I made it as short as possible, the motor ran like a dream.
Kyosho RRR Evo2
Old 04-15-2004, 05:20 PM   #10
theRED5's Avatar
R/C Tech Charter Subscriber
Were all those cars you saw the long pressure line on NTC3's? They run them to keep the tank from foaming so much when the fuel level gets low, so the engine doesn't get lean.
ROAR has a limit on the length of fuel line going to the carb...You can get longer run times, and spoil the 75cc fuel tank rule. If your running a 5 port in a MTX3, I imagine that your running outlaw. Or someone may protest your entry, out of a Main.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
back pressure effect on performance, mileage, - max power back pressure adjustment tomkelley Nitro On-Road 4 07-31-2008 05:12 AM
Return fuel tubing length - how to lower pressure in tank charlesd Onroad Nitro Engine Zone 3 06-13-2008 11:32 PM
Purple Fuel Tubing Accord Nitro On-Road 14 05-13-2003 11:14 AM
fuel tubing corvettecrazy Electric Off-Road 2 01-25-2003 08:51 PM
fuel tubing corvettecrazy Nitro On-Road 8 01-22-2003 03:05 AM
