RS4 Engine Advice
Hello Everybody!
I have a old HPI RS4 Evo and I need to get a new engine for it. The old engine was very unreliable and tuning it was a pain. I just want to get a new engine that is reliable. I don't care if it has low power I just want something that will last a while. I do not want to spend over $150 on it. Anny suggestions? |
Get the os .18 cv-rx abc with 11j rotary carburator it's 135 nd it's a good engine, my rs4 is equipt with it good luck
what about this one? Does it have enough power?
http://www.rcplanet.com/ProductDetai...11523&CartID=1 |
Originally Posted by fishymamba
(Post 7150890)
http://www.rcplanet.com/ProductDetai...11523&CartID=1 im not sure how much the power the HPI 3.0 makes, but its probably more power than the .15 CV if that bothers you at all. |
Originally Posted by Turbo9000
(Post 7151065)
Great little motor, I had one about 10 years ago on my RS4. and my girlfriend's RS4-2 currently has one. Claimed output was about .67 hp, super easy to tune and not too tempermental. It has plenty of power for a parking lot racer. It was a great club-level motor. At that time novarossi had a .12 side-exhaust that made 1hp.
Originally Posted by Speedychris22
(Post 7148201)
(Post 7152019)
If I get this engine can I use the flywheel/clutch bell from the old engine? Will I need to get any special engine mounts?
(Post 7153291)
You could use the same flywheel and clutch but why not upgrade. You will need engine mounts get HPI #86045 For clutch you will need HPI #A925 and clutch #87191. It is a pull start so u will need to schim down the upper deck some. Good luck
Never mind I looked at a few picture and I understand now. Thanks for the info everyone I am probably going to get the O.S. .18 CV-RX because it has more power than the .12. Thank you for the help everyone!
