Old 04-12-2004, 07:24 PM   #16
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default foams!
Foams for sure! Try some of the G.Q Tires, they are flying off the shelves like crazy!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-14-2004, 06:38 PM   #17
edseb's Avatar
Coldeye:
I ran at the last Castle Park race. I ran 19t and stock. Nitro is something I've always wanted to try and I'd like to get the car close before I show up. Thanks for the tips all.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 04-14-2004, 06:38 PM   #18
edseb's Avatar
BTW. I go by Carl and sit under the DC tent.
Carl Hyndman
Old 02-13-2005, 07:08 PM   #19
Neil's Avatar
Send a message via MSN to Neil
Have any of you guys tryed these? http://www.medialpro.com/english/pro...us/10piste.htm
I'm running on sealed blacktop.
Neil is offline   Reply With Quote
Old 02-14-2005, 09:50 AM   #20
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
i use those before they worked pretty good
Old 02-14-2005, 10:06 AM   #21
roadrage's Avatar
Trader Rating: 14 (100%+)
they work real good when it is damp or wet out.
Austin Wolfe
Serpent America-Trinity/Revtech-www.ActivRC.com
roadrage is offline   Reply With Quote
Old 02-14-2005, 08:19 PM   #22
Send a message via AIM to Evilpete
I usually start with 40 shore all around, seem to hold up well and last longer
Evilpete is offline   Reply With Quote
Old 02-18-2005, 07:17 AM   #23
kewdawg's Avatar
Try 35 shore when its cool (65 degrees or less), 37 shore when its a little warmer (65 degrees - 80 degrees) and (40 shore for 80 degrees to 95 degrees) - lastly, if, it's extremely hot or the track has a ton of traction, try 42 shore. You should be able to use 26mm front and 30mm rear without a problem. Nitro cars are designed to use those widths. Give either Ellegi or Power Tyres foams (basically the same tire made by GP) a try. Also, give, my current and Stateside nitro tire favorite, Twistertires a shot. They're really good! Good Luck.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 02-18-2005, 10:41 AM   #24
Neil's Avatar
Traction is never really that high we have to spray soda on the run line if it doesnt rain in between races it gets better. How do rubber tires compare to foam? On this type of surface. The only spec at the track I race at you need to have a .12 size engine and thats pretty loose also. I'm trying to get away from foam tires because I dont have a tire lathe. One of the guys has one but I hate asking all the time.
Old 02-18-2005, 10:49 AM   #25
Super Moderator
Marcos.J's Avatar
you usually will run a different set up on your car between using foam and rubber tires.
Old 02-18-2005, 12:29 PM   #26
Neil's Avatar
I guess what I'm asking is can a car with rubber tires be tuned to be as fast as one with foams?
Old 02-18-2005, 01:36 PM   #27
Super Moderator
Marcos.J's Avatar
help is on the way!!
Old 02-18-2005, 01:52 PM   #28
calstarjig90j's Avatar
Takeoff premounted CS-27's work well in parking lot races but don't last very long.
calstarjig90j is offline   Reply With Quote
Old 02-18-2005, 01:54 PM   #29
NiMo's Avatar
someone call me?
Oh! rubbers again
Yes rubber can be made to go as fast as foam, but only over a 5 minute run, and the tyres will be close to canvass after 5 minutes.
The tyres I used were Sorex 24 with Echo 4430S inserts and ING wheels, but this set up was on an FW05 with loose diffs and a Touring MG ZS shell. Cannot say if it will work with other cars.
NiMo is offline   Reply With Quote
Old 02-18-2005, 02:06 PM   #30
Oasis's Avatar
Trader Rating: 36 (100%+)
Where I race at the Experts can run foams everyone else runs rubbers,The problems i have had in the past with rubber tires is when you try to run a soft compound your tires will work for about 4 to 5 minutes and they(your traction)goes away,when it's cold I run 30's or 27's but most of the time it's 32's or 36's,with that said..Foams just give you alot more traction for most conditions..remember that you still need to use the right compound for the conditions and track your running on.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Parking lot racing? jiggamacdaddy Georgia Racing 25 03-28-2006 05:10 PM
ld3 and parking lot racing. fishstix Nitro On-Road 1 12-13-2004 01:10 PM
Parking lot Tires. fatdoggy Electric On-Road 33 04-06-2003 07:01 PM
What tires and inserts for parking lot racing? CRASH Electric On-Road 12 04-03-2002 03:12 AM
