Old 07-31-2010, 02:27 PM   #31
Send a message via MSN to PMSorber
Although the game is not over you are compleetly right, it is nothing, it will not work, it is not innovative and it is stupid for a company like Serpent to build such a system. Your observation of my driving is compleetly right, although my laptimes are faster I did become slower in the corners.....
And the Shepherd is the best car to have. I did found this on another forum about the brands used on the current standing:
Yes, Shepherd is leading the list, and there is no Serpent in front of a Shepherd, Even the complaining Xray customers wanting a NT2 because the NT1 is outdated are compleetly right as also all Mugen drivers waiting for a MTX5 because the MTX4R is very outdated.
No there is no Serpent or Shepherd leading the list and if you cant stand any negative reactions here, its better to not post at all then Roelof. I also do not understand what al this rubbish has to do with my post.
Originally Posted by Bart_Banaan View Post
And rightfully so, the sarcasm is well used. PMS is over-negative...
Dear Jaap, I am not over-negative but speaking out of expariance... dont think this is not tested before as far as I recall about 2 years ago by some guys who tend to drive WC finals but that was 1:8 scale.
Maybe it could work on 1:10, I have no experiance with that.
So thats why "lets wait and see", nothing over-nagative about that.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 07-31-2010, 03:03 PM   #32
Roelof's Avatar
Send a message via ICQ to Roelof
Do not talk if you are experienced, you are not. How can you tell my speed in the corners were slowed down if my laptimes are better, that must come from somewhere and for sure not from the parts between the corners.....
If you do know it all so well, come with names and brands, it is very simple to say you know all but do not give any prove. If it did not work then why are there better results with me and my friend? Why did Serpent introduce it at the WC?
I can only imagine that your guys did do something wrong......
Or maybe we are thinking to complex while a kid can drive with it into the finals......
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-31-2010, 04:03 PM   #33
Its going to sound a bit like "who has the bigger balls"...
Lets see what the next years will bring Roelof, and remember... no results no market. Keep up the "good" work!
@ConSult Trading
Old 08-01-2010, 04:22 PM   #34
KweetNiet's Avatar
It's not about balls or brands, it's about a piece of techic what is beeing used. Let's wait and see if it can bring some extra. Ones the guys are back from the wild west and it becomes available it will be tested. Even as we speak somebody already made it for his NT1 and will test it.
If the system really works others will adapt. Maybe when the NT2, MRX5, Velox V11 and V2-RRRRRRRRRR will have it or at least will have it as an option, it proved to be something to keep close by.
KweetNiet is offline   Reply With Quote
Old 08-02-2010, 05:19 PM   #35
Fuin's Avatar
Though this suspension system permits constant camber, it is a dependent suspension so when the suspension is force to jaunce a lot you loose grip. This suspension is probably only competetive on really smooth tracks and also probably works better on larger cars.
Fuin is offline   Reply With Quote
Old 08-23-2010, 01:59 PM   #36
Any positive progress with Dax lately?
@ConSult Trading
Old 08-24-2010, 03:47 AM   #37
Roelof's Avatar
You do believe it is not working so why the interest?
But I was forced to drive a race without it due much play what was not the cause of less grip in the previous race, if we did get rain I would have mounted it again because then even with some play there are huge advantages. After rebuilding the rear end it was clear the driveshaft pins did create a huge sleeve into the wheel axles and that was just from the last time. I know it is heavy for the pins because I had to replace them more often, not that strange with a solid rear shaft and 2 wheels steady on the ground.
The drawings of the needed part is already at the factory and when they have the time they will create some in a smal production. Drawings are in the attachements.
Old 08-24-2010, 05:22 AM   #38
the system seems great as it eliminates camber gain and keeps the wheels on flat on the ground.
how do you think this system will work on a 1/10?
although this system seems great, what about the effects of 1 wheel bump as the suspension works dependent on each other.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-24-2010, 05:57 AM   #39
Roelof's Avatar
This system works the same as the Serpent DLS system with only a better working as an anti rollbar. With the links also comming from the upper wishbone and keepng the wheel flat on the surface the system is more pulling from and pushing to the other side.
It creates understeer you have to solve with the front but you can take away the rear trimstrip and set less toe-in at the rear creating a faster acceleration and more speed. Due the huge grip you can go on full throttle out of a corner wthout losing the rear end (OK, there are limits...) but the only bad thing to learn to live with is it going wide out of the corner.
Bump up one wheel can be tricky. The other wheel will lost his flat connetion making the car a bit unstable, some play in the system seems to eliminate it a bit. Running on a flat track avoiding the curbs and dots you should not notice one thing.
Old 08-24-2010, 06:05 AM   #40
how about independent suspension?
instead of running the link to the opposite wheel. run a short tierod up, so it only affects the single wheel camber.... if u get what i mean
Old 08-24-2010, 06:29 AM   #41
Roelof's Avatar
Something like the Michelin OPS system used on the mid 90's Renault F1 cars?
Old 08-24-2010, 07:15 AM   #42
just a quick drawing i did with paint
so there will be no camber gain, and will work in conjunction with antiroll bar when cornering etc.
Old 08-24-2010, 08:43 AM   #43
Roelof's Avatar
Interesting, almost the same principle but less influence from the other side. I do not know if that is good or bad but it does eliminate a bit the unstable becomming car on the bumps if only one side takes the bump. Try to put it into a 3D simulation software. I know there is a program called SUSPROG which can calculate suspensions but I doubt it can work with these kind of setups.
Another driver in the Dutch championship did create a different geometry on the rear end with just a dubble whisbone setup. He will keep both wheels steady and straight on the ground when the chassis makes a roll. Only when the chassis is going up and down the geometry is losing it. With the 1/8 cars the body is not pushing on the chassis and so the chassis will stay on a certain height making it work.
Old 08-26-2010, 04:40 PM   #44
Default Dax / DLS / V-Cam
Wow, Roelof this system is really getting popular, I am now seeing it being tested on the front end.
V-Cam
+ YouTube Video
jelayne is offline   Reply With Quote
Old 08-26-2010, 04:48 PM   #45
wingracer's Avatar
Trader Rating: 24 (100%+)
Interesting, though I don't think it's really needed at the front since we don't have front brakes.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
The Formula One / Mini RC Club oldskul Manila Racers 9272 10-13-2016 06:14 AM
MRX-4X chicky03 Nitro On-Road 1676 09-17-2016 12:34 PM
WHAT DO YOU THINK ABOUT THIS! Seisick Nitro On-Road 12 09-30-2008 12:22 AM
