Old 04-10-2004, 11:40 PM   #1
racer's Avatar
Default engine start up (non-pull start)
need some pointers to start up a non-pull start engine.
this is my first time dealing with a non-pull start engine.
i have a starter box and all, just don't know how to start the engine. i read somewhere that the starter box should rotate clockwise while the flywheel turns counter-clockwise.
my ignitor is working. is there a way to prime the motor?
also my concern is, when i place the flywheel on the starter box and push down to make contact with the starter boxes rotating wheel. the motor seizes up at the top/bottom stroke. i can't get the motor to turn over.
any help would be appreciated.
Thanks in advance!
racer is offline   Reply With Quote
Old 04-11-2004, 12:22 AM   #2
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Welcome to Nitro. You will love it if you're patient
"this is my first time dealing with a non-pull start engine.
i have a starter box and all, just don't know how to start the engine. i read somewhere that the starter box should rotate clockwise while the flywheel turns counter-clockwise."
Yes, the flywheel goes counter clockwise and the starter box wheel goes clockwise. Just make sure the car is aligned with the box. Make sure the middle of the flywheel contacts the middle of the starter box wheel.
"my ignitor is working. is there a way to prime the motor?"
A way to prime the engine is to plug the exhaust stinger hole.
Another way is to take off the pressure line connected to the pipe and blow on it. This is a bit dangerous since you might suck up some nitro.
"also my concern is, when i place the flywheel on the starter box and push down to make contact with the starter boxes rotating wheel. the motor seizes up at the top/bottom stroke. i can't get the motor to turn over."
An easier way to turn over the engine when the engine is hard to start is to heat the engine up with a hair dryer or heat gun, to expand the metal inside.
Hope this helps
DOMOisCOOL is offline   Reply With Quote
STS .28 pull-start engine dino.tw Onroad Nitro Engine Zone 632 08-31-2009 07:10 AM
Wanted Pull start/roto start for collari .30 seajj2 R/C Items: Wanted to Buy 5 08-31-2005 05:51 PM
Best pull-start engine? rossiRocket Onroad Nitro Engine Zone 6 01-12-2005 12:05 PM
Best pull-start engine? rossiRocket Nitro On-Road 0 12-10-2004 01:15 AM
Exactly how do you start a pull-start motor? <Don't flame me because I'm dumb!> Vyrus Track Locator Forum 1 08-20-2004 06:39 PM
