Old 04-08-2004, 07:51 PM   #1
teammediocre's Avatar
Default 200mm outlaw bodies
Where can you get 200mm lola style bodies other than Yokomo?
teammediocre is offline   Reply With Quote
Old 04-08-2004, 08:53 PM   #2
Trader Rating: 16 (100%+)
Too many...
Tower (Racer choice)
www.speedtechrc.com (Frewer).....
Serpent (Lola or 956)
Old 04-09-2004, 02:42 PM   #3
mckrooz's Avatar
Send a message via AIM to mckrooz
I like the Racers Choice Lola. It comes with the wing and the side stiffener. The Frewer doesn't.
mckrooz is offline   Reply With Quote
Old 04-09-2004, 02:59 PM   #4
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
I like the Frewer Porsche 911 GT1 body
DOMOisCOOL is offline   Reply With Quote
Old 04-09-2004, 03:32 PM   #5
doki_doki's Avatar
Location: Cebu City, Philippines and Ocala, Florida, USA
Default Frewer Proche 911 GT body
this body is cool man as compared to the other lola bodies out there...
doki_doki is offline   Reply With Quote
Old 04-09-2004, 03:43 PM   #6
Which outlaw body will fit without a lot of holes on the NTC3 rear exhuast? i tried the yoko lola but ended up having to cut holes for the front shock tower and the header.
R1ceboy is offline   Reply With Quote
Old 04-09-2004, 04:09 PM   #7
Send a message via ICQ to mtx3racer Send a message via AIM to mtx3racer
i have frewer racing lola bodies for sale anybody? I need to sell them ASAP, and i will sell cheap
mtx3racer is offline   Reply With Quote
Old 04-09-2004, 06:59 PM   #8
Your option, is NO OPTOIN, if you want to use something like that you MUST use the Porsche 956 stype one (with the driver housing type) because no matter how low you shave your shock tower, you cannot fit the LOLA nicely unless you raise the body up and have those ugly fender gap....I did that on my NTC3 but I have to custom made a special shock tower and front body mount with the V1RR plate to make it fit....and I don't think you want to go thru all those trouble.
The Porsche one will fit the NTC3 very nicely, but still, you can only mount the front shock to the lowest hole and you have the cut the EAR off of that front shock tower.
Regarding HOLES on the NTC3 chassis, there is nothing you can do, you have to punch at least 3 holes for the NTC3 just like for any other nitro car....(Gas tank, engine and intake.....then small on the side for exhaust.)
Old 04-09-2004, 10:07 PM   #9
what about mounting on a impulse?any one tried?
Old 04-09-2004, 11:25 PM   #10
Then you have to do the whole IMPACT convertion....you will need the whole GTP floating mount at rear, Impact dogbones, rear impact uprights...........
On front, you can only mount the shocks wtihout the shock tower, at the lowest position....then you can use the Impulse GTP front bumper, and you have to custom cut a Impact front body mount...
But on Impulse, you can use LOLA or Porsche borh....
Old 04-10-2004, 12:32 AM   #11
Rapid Roy's Avatar
You can always do it the old school way. They used to heat the body up with a hair dryer at the spot where the interference is. Once the lexan softens, just press the body down and you get a bump where the offending part sits.
Rapid Roy is offline   Reply With Quote
Old 04-10-2004, 10:53 AM   #12
mossberg590's Avatar
100% correct!! Have done that when I started racing my Impulse Pro 2 years ago. Sad thing that VDS classes had died here in the Philippines. Eventhough Im racing my 710, I still get kicks running my Impulse VDS on my private track ones in a while. I wish we could bring back that class here.
mossberg590 is offline   Reply With Quote
Old 04-10-2004, 10:55 AM   #13
ianhobbies's Avatar
Location: Costa Del Sol, Marbella, Spain www.bradir.net
Send a message via ICQ to ianhobbies
Default lola bods
GTi model bodies is also a great choice
ianhobbies is offline   Reply With Quote
Old 04-11-2004, 12:22 PM   #14
InitialD's Avatar
Dude, you do not need the Impact dogbones and the Impact rear uprights. The Impact dogbones are used when you use an Impact rear ball diff / FPS diff or Impact solid axle. The Impact has the same uprights as the Impulse / 705.
For the conversion, you need 3 things... The GTP set 808150, the Impact rear shock tower 808139 and the GTP / CanAm front bumper 808121 or Impact's more durable Lola bumper 808120.
Old 04-12-2004, 01:19 AM   #15
Default Bringing back the VDS class
Just want to ask you guys if VDS class is as active as 200mm touring in your area. Iam very much interested in bringing back that class, at least in my local track. I consider it to be more competitive and exciting. Any input from would be greatly appreciated. MAny thanks.
GT! 200mm bodies itchy b Nitro On-Road 10 08-27-2008 08:50 PM
1/10 200mm Bodies PUNISHER R/C Items: For Sale/Trade 5 07-10-2008 01:26 PM
Outlaw bodies? ChadRacing Oval, Larger Scales and More 6 10-05-2006 06:46 AM
200mm 1/10 Outlaw Class rcscrewz Nitro On-Road 24 08-18-2006 08:58 AM
200mm Outlaw Car/Class EJRacer Nitro On-Road 14 07-02-2006 03:01 PM
