Old 04-08-2004, 02:08 PM   #1
Registered User
junito yukiyu's Avatar
Send a message via MSN to junito yukiyu
Default Shock oil
What woul be the equivalent to mugens 600 shock oil?? , the problem i have is that i can't find the mugen one and i'm gonna have to use something else...
junito yukiyu is offline   Reply With Quote
Old 04-08-2004, 02:09 PM   #2
teammpp's Avatar
Default Re: Shock oil
I believe Associated or Serpent 60wgt oil is the equivilent although not totally sure.
teammpp is offline   Reply With Quote
Old 04-08-2004, 02:44 PM   #3
EVOLUTION's Avatar
Default Re: Re: Shock oil
I had a chart once with the mugen/asso oil conversion but I can't find it at the moment. It was definitely not 60W I think it was more like 55W or a bit less. It would be best to just try a bit harder and get the mugen oil for a mugen car so you can compare setups etc.
EVOLUTION is offline   Reply With Quote
Old 04-08-2004, 04:21 PM   #4
mckrooz's Avatar
Send a message via AIM to mckrooz
It's more like 50wt. I believe the actual conversion is 48wt.
mckrooz is offline   Reply With Quote
Old 04-09-2004, 01:26 AM   #5
rice's Avatar
close to 50w
rice is offline   Reply With Quote
Old 04-10-2004, 07:01 PM   #6
JustRace's Avatar
http://www.twf8.ws/new/tech/tip/shock.html
Based on this site it should be somewhere between 45-50 wt.
JustRace is offline   Reply With Quote
Old 04-10-2004, 09:50 PM   #7
sbmon's Avatar
My friend told me that he heard it is like 47.8 from a viscosity test someone did. if you can't find it just mix 1/2 bottle of 45wt with 1/2 bottle of 50 wt and you should be pretty close
sbmon is offline   Reply With Quote
Old 04-11-2004, 08:25 AM   #8
I was told by a vet at the track that Mugen 600 is more like Serpent 30W. I was also told that Serpent 40W is like Associated 80W.
trey is offline   Reply With Quote
Old 04-11-2004, 01:12 PM   #9
Registered User
there's all kinds of opinions and i like that!
FS: LST shock with hard coated body and Ti-Ni shock shaft yahhoo R/C Items: For Sale/Trade 6 03-27-2008 01:04 PM
NEW HPI Shock Set SteveM R/C Items: For Sale/Trade 0 03-18-2008 09:08 AM
CST SHOCK OIL AND SILCONE SHOCK OIL Quietroit Nitro On-Road 2 02-09-2008 06:43 PM
TC3 FT aluminum shock tops w/Lunsford "quick tune" shock mounts? billwilner Electric On-Road 2 01-06-2005 08:49 PM
NTC3 Shock and Team Associated Shock Caps Question jcrouse Nitro On-Road 4 07-13-2003 10:11 PM
