Old 03-03-2010, 12:35 PM   #1
Default L8ight GT Touring Setup
Anyone using the L8ight has a GT car? Can you please post / share your setup? Thx.
chumanji is offline   Reply With Quote
Old 03-04-2010, 09:55 PM   #2
Trader Rating: 15 (100%+)
I ran a L8ight in the GT class last year. The first thing I realized was that I needed harder springs. Losi ended up coming out with some stiffer springs and I think rc4less has even stiffer springs.
Good luck!
Arboleda is offline   Reply With Quote
Old 03-05-2010, 01:24 AM   #3
What kind of diff and shock fluid would you recommend for this car. I will be running at a indoor track with lots of traction.
Old 03-06-2010, 12:42 AM   #4
I'd try starting at something between 50K and 100K for the front diff. In the rear I'd try 10K to 20K.
For shocks, we go pretty heavy on the fluid here. It's not unheard of to use something in the 700 to 1K range.
Let me know if you want the 700 to 1000 translated into Losi numbers (these numbers are mugen/xray/etc weights).
Old 03-08-2010, 08:28 PM   #5
motomike122's Avatar
I see you are running Losi's L8ight model on road in the GT class. What motor/pipe combo are you using and what is the gearing you are running. I was thinking of doing this but thought since it's only a single speed it would be a loss. Your insight would greatly change my mind since I'm a LOSI NUT!!!!!!Thanks, Mike
motomike122 is offline   Reply With Quote
Old 03-08-2010, 08:34 PM   #6
We run on small to medium tracks in Utah, so the lack of two-speed didn't hurt me too much. How big are your tracks, mike?
Old 03-08-2010, 08:44 PM   #7
It's a pretty good size track. Long back straight. Track is called Control Freakz in Chaplin,CT I'm thinking I would need a two speed or what size pinon will make more top speed??? Did you run the spool type front diff? Didi it make a difference and how?? Thanks, Mike
Old 03-12-2010, 09:36 PM   #8
Old 04-02-2010, 06:26 AM   #9
air8's Avatar
I've been trying to get the Kyosho GT guys to give me some info on how long the diff mount is, and how long the 2-speed is from outdrive to outdrive. I think I can make the 2-speed work on the L8ight if I can get the right driveshafts. But I'd like to find out the length of the Kyosho tranny first.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-02-2010, 07:29 AM   #10
Timmo's Avatar
Those Kyosho guys are secretive about there stuff.Do you agree.
Timmo is offline   Reply With Quote
Old 04-02-2010, 12:47 PM   #11
Do not use the stock 2 speed from Kyosho. Most guys are tossing them for the Ipanema Black Hawk tranny and others are using the OFNA trany for Kyosho.
jneg is offline   Reply With Quote
Old 04-02-2010, 12:53 PM   #12
air8's Avatar
Hmmmm, I'll have to check that Ipanema out later when I get home. I didn't think about the ofna stuff. But i did used to use my Losi engine mounts on the dirt oval ofna car before the L8ight came out. LOL. so now maybe i can get the Ofna tranny to work on the Losi car.
--"U Ain't Fast!!"
Chris Pearce
Old 04-02-2010, 03:46 PM   #13
mcsquish's Avatar
Kyosho just released a 2-speed also. The Black Hawk is better but I'm not sure if you will need the drive shafts.
If you can get to work, that would be awesome! I looked at the layout of the 8T but didn't think a 2-speed would fit.
Good Luck
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 04-02-2010, 03:55 PM   #14
wwoodruff
Guest
Posts: n/a
The Blackhawk 2 speed and the new Kyosho shoe type two speed are about the same length, looooong. About 43mm long center to center of the bulkheads. Good luck, those Losi cars do not have much room. Moving the front bulkhead forward would make the driveshaft angle even more extreme. d
Got questions, just ask..
Old 04-02-2010, 08:18 PM   #15
air8's Avatar
My only questions are wether the 2-speed is longer than the standard diff in the Losi. If it is I think the HB D8T front drive shaft could be used. But I'd need to research more for a correct length rear shaft. Basically I have a 1.0 truggy sitting around and I really need to get a Kyosho body on. LOL .
--"U Ain't Fast!!"
Chris Pearce
