Old 04-20-2010, 12:13 PM   #31
air8's Avatar
So far so good. The TT tranny is the perfect length. The stock diff mount should work just fine. I need to get a couple bearings though. The TT tranny has a smaller out put shaft so I need a 5mm i.d. bearing. The Losi diff mount uses a 14mm o.d. bearing and the TT bearing is 16mm. So two 5x16 bearings will take care of that.
Now I'll order a clutch bell and clutch bell bearings, and a 3-shoe clutch set up; springs, shoes, washers, flywheel. Hopefully all this will go in and the buggy tank will be short enough on the truggy chassis to allow room for the CB. I'm hoping the Kingheadz engine mounts, when flipped around, will move the engine back far enough to allow the CB to line up with the tranny.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 04-21-2010, 06:06 PM   #32
Great to hear the TT tranny worked for you. I have a SC8 that I will see how it converts to GT.
jneg is offline   Reply With Quote
Old 05-05-2010, 12:55 PM   #33
air8's Avatar
Anyone know where to get 5x14x4 flanged bearings? I checked Ready Rollers, Boca, and Avid, and VXB.
--"U Ain't Fast!!"
Chris Pearce
