Old 03-31-2010, 07:45 PM   #31
curth's Avatar
Send a message via ICQ to curth Send a message via AIM to curth Send a message via Skype™ to curth
Originally Posted by nitrohead5300 View Post
.................................Not a myth you put a .highly modified .18TZ or a NovaRossi .21 and watch how fast the stock diffs will blow up.
well duh.
Did I really have to say "the diffs hold up fine under race-loads" not "modified lets-see-what-fits loads"?
curth is offline   Reply With Quote
Old 03-31-2010, 08:33 PM   #32
Well duh if you read the whole thread you would know we were talking about big blocks and modified motors.
nitrohead5300 is offline   Reply With Quote
Old 04-01-2010, 07:03 AM   #33
RCAKid's Avatar
Originally Posted by *BBB* View Post
How much more power do you get when you modify the .18tz? and who do yall get to modify them?
Murnan Modified i have been running his since i started racing 5 years ago and they are alway awesome. there really consistent easy to tune and extremely fast. in my oppinion the best modifier out there they can be found here www.murnanmodified.com
sponsors
Murnan Modified Motors- RbM3
Rc America- Nt1
Mom & Dad
RCAKid is offline   Reply With Quote
Old 04-01-2010, 08:24 AM   #34
*BBB*'s Avatar
That cats mods are EXPENSIVE! abmods seems to be pretty good to me and good price too
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 04-01-2010, 06:33 PM   #35
*BBB*'s Avatar
What bodies fit the TC3? The 190mm tc? 200mm tc?
Old 04-01-2010, 07:02 PM   #36
lil-bump's Avatar
Trader Rating: 83 (100%+)
The TC3 is an electric car it uses 190mm. The Ntc3 is a nitro car it uses 200mm. Most 1/10 scale nitro onroad cars use 200mm bodies
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-01-2010, 07:36 PM   #37
Turbo9000's Avatar
Originally Posted by lil-bump View Post
Nitro onroad cars all use 200mm bodies.
well, not all 1:10 nitro on road cars are 200mm
Turbo9000 is offline   Reply With Quote
Old 04-01-2010, 07:39 PM   #38
lil-bump's Avatar
Yes you are correct. Most 1/10 scale nitro onroad cars use 200mm bodies
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-01-2010, 09:08 PM   #39
*BBB*'s Avatar
Thanks! Man that setup looks SICK! Can anyone tell me where to get the OFNA steel diffs that fit the NTC3?
Old 04-01-2010, 10:02 PM   #40
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
id like to know where to get steel diff gears as well
RCNitroDude999 is offline   Reply With Quote
Old 05-20-2010, 09:19 PM   #41
R40Victim's Avatar
Does anyone know if a stock fuel tank will work with the K factory chassis? The K factory low profile tank on mine cracked. I don't have a stock tank to compare.
R40Victim is offline   Reply With Quote
Old 05-20-2010, 11:43 PM   #42
Ballistik Mods's Avatar
Yes it does the mount points are still the same .
Ballistik Mods is offline   Reply With Quote
Old 05-21-2010, 06:30 AM   #43
.............Check nitrohouse they might have some. Link http://www.nitrohouse.com
Old 05-21-2010, 08:03 AM   #44
R40Victim's Avatar
COOL! Thank you!
Old 05-23-2010, 06:38 PM   #45
warnos's Avatar
Default Beef up the Diff
I am trying to beef up the diff on my NTC3 aswell.. put a OS.12TZ in it and I am very worried the diffs will not hold up..
I have them shimmed and wanted to but a spool in the front.. but I don't think the plastic gears in the diff can handle it..
Has anyone actually put a steel gear set in the diff?? Nitrohouse doesn't have one..
There was a option years ago which recomended putting just the steel gear on the diff and not the drive shaft pinion leave it plastic..as it would wear to fast with them both being steel..
So has anyone got any diff upgrades they have done.. I would even replace the whole diff it it works with something else. A sealed diff would be awsome.. or should I just get the standard diff an keep it shimmed... its just so hard to get too all the time..
Cheers
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
RS4 Pride J Smith Nitro On-Road 11 08-08-2004 02:33 PM
