Old 04-05-2004, 06:28 AM   #1
Default assembly problem with ld3 two speed
hey guys,
I am in the process in building a ld3 pro and I came into a problem trying to install the 2 speed together. For some reason I cannot get the retaining clips onto the gears to keep everything in place
sKiMpYbOy is offline   Reply With Quote
Old 04-05-2004, 08:13 AM   #2
spenzalii's Avatar
Send a message via AIM to spenzalii
One of the e-clips looks like it's bent. Try to flatten it out if possible.
The clips go into the groves on the gear holders. Your best bet is to make sure the gear is pressed on all the way so you can see a slight lip at the edge, then snap the clips on. It is 10000% easier to get those clips on if you have an external snap ring tool. You can pick up a set at your local auto parts store, Lowes, HOme Depot, Sears etc for under $12, It works much better than trying to use needle nose pliers (although in a pinch they will work too)
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 04-05-2004, 10:38 AM   #3
Trader Rating: 16 (100%+)
Does you guys know where to order the LD3 PRO centax clutch with 28T tooth in USA or any ONLINE STORE? Thanks........
Old 04-05-2004, 09:15 PM   #4
spenzalii's Avatar
www.nitrohouse.com is probably your best bet in the US. They have the tranny, clutch and gears
OS Speed 21 Low Speed Needle Problem chrisv Nitro Off-Road 2 07-13-2008 08:47 PM
Speed problem! Big Jeff BBQ Georgia Racing 0 02-29-2008 05:52 AM
Problem with diff assembly...please help. Paul Whalen Electric Off-Road 3 12-27-2007 07:57 PM
Serpent Vector assembly problem Orfeous Nitro On-Road 4 12-20-2006 01:14 AM
LK: HPI Nitro 2, 2 Speed assembly FUK_WRX R/C Items: Wanted to Buy 0 06-25-2003 07:19 PM
