Old 04-03-2004, 07:31 PM   #1
chachi's Avatar
Default Factory settings Novamega SX12 SS?
Does anybody know the factory settings for the SX12 SS? High-speed? Low-speed?
Thanks.
chachi is offline   Reply With Quote
Old 04-03-2004, 07:34 PM   #2
fmolzer's Avatar
They usually come in around H.4.5 turns out L:0.75-1 turns out Middle: flush (about 1.75 turns out)
fmolzer is offline   Reply With Quote
Old 04-03-2004, 07:39 PM   #3
chachi's Avatar
Thanks for the quick reply....much appreciated. Now I can get on with break-in....
Old 04-03-2004, 07:39 PM   #4
Manticore's Avatar
R/C Tech Charter Subscriber
they are all novarossi carb. setting on starting point should be main: 4.5 turn out and low:3.5 turn out. adjust from that point
Manticore is offline   Reply With Quote
Old 04-03-2004, 07:45 PM   #5
chachi's Avatar
uh oh.....so 1 out or 3.5 out for the low-speed?
Old 04-03-2004, 11:56 PM   #6
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
3 and 1/2 out from closed.
Racing4Evo is offline   Reply With Quote
Old 04-04-2004, 04:53 PM   #7
fmolzer's Avatar
Are you guys sure on the 3.5 out on the L? I checked three of my engines and they all came in with about 0.75 to 1 turn out? Engine seems to run just fine at that, sometimes I will go to 1.5 out but never more than that.
Old 04-04-2004, 05:15 PM   #8
AMGRacer's Avatar
3.5 seems to be around the factory setting. I have been as low as 1.5 like you mentioned, but this is likely a little lean.
AMGRacer is offline   Reply With Quote
Old 04-04-2004, 06:06 PM   #9
FAST1's Avatar
He is asking for a base stock settings...........
Your motors are probably worn in and on the lean side.
FAST1 is offline   Reply With Quote
Old 04-04-2004, 07:41 PM   #10
fmolzer's Avatar
Well, Your theory would be correct, except that for every engine I buy I note the needle setings as they are outof the box, on the inside of the box lid itself. Anyway, if you have to err, I guess going rich is always better.
Old 04-04-2004, 08:00 PM   #11
rjl
rjl's Avatar
My bottom end needle is between 1.5- 2.5 turns out on most of my engines.
rjl is offline   Reply With Quote
Old 04-04-2004, 08:04 PM   #12
rjl
rjl's Avatar
Just checked a new Rody V12, 3 turns.
Old 04-05-2004, 05:53 PM   #13
chachi's Avatar
Old 04-05-2004, 05:54 PM   #14
chachi's Avatar
I checked mine before I put all the adjustments back to factory settings and it looks like the low-end was around 3.5.
fmolzer: what engines are you talking about specifically?
I like the idea of a thread with base settings for the various engines. It would be handy for the future.
Old 04-05-2004, 06:53 PM   #15
fmolzer's Avatar
NS3 .12:s I just checked the one engine I have left that is not even broken in yet, it acctualy ahs a low end needle setting of 1.75 turns from fully closed. These are all hand modded Novamax engines, but I would not ecept them to be that much different??? My NovaMega .12 really, really did come with the low end needle at 0.75 tuns out. hmmmm. 3.5 certainly sounds very, very rich to me, but it appears that there are some variations here. I checked the Novamax that was n my car during winternats, and it has a lowend of 1.75 turns out and I know that worked on the track for a fully broken in engine.
base needle settings on novamega sx12 ss charlesd Onroad Nitro Engine Zone 0 10-01-2007 07:34 AM
DOES ANYBODY HAVE THE NOVAMEGA 12 FACTORY SETTINGS Corey The Great Australian Racing 3 05-18-2006 02:32 AM
Novamega SX12 help Yokomo_King Nitro On-Road 0 03-27-2003 09:33 PM
Where to buy NovaMega SX12 RE 5P Turbo MS smash123 Nitro On-Road 17 10-23-2002 02:21 PM
Novamega SX12 RE 5P TURBO smash123 Nitro On-Road 8 09-27-2002 08:56 PM
