Old 03-14-2002, 12:33 PM   #1
Default Flywheel stuck
Friend was running his finger over the flywheel and tried to force it to rotate completely. Now it's stuck.
How do I get it unstuck now?
ChinBoy is offline   Reply With Quote
Old 03-14-2002, 12:50 PM   #2
If it is in your car than just use your starter box and just do a quick bump. It is normal not to be able to turn it all the way.
BallPy is offline   Reply With Quote
Old 03-14-2002, 01:02 PM   #3
Send a message via Yahoo to TambokGT
if the piston locked just use a hair dryer wait for the sleeve and piston parts to heat up ...by then you can easily turn the wheel again.
TambokGT is offline   Reply With Quote
Old 03-14-2002, 01:04 PM   #4
Well, I guess I am stupid. I should of thought of that.
Old 03-14-2002, 01:05 PM   #5
Talk about quick!
Thanks!
Old 03-18-2002, 07:35 PM   #6
Send a message via AIM to audi_711
Default Maybe
Maybe u should take th engine out and see wahts wrong with it. maybe something is stuck like a rock or something that has happened to me a few times with my mugen
audi_711 is offline   Reply With Quote
Old 03-18-2002, 08:48 PM   #7
Mauler's Avatar
Send a message via ICQ to Mauler
Default Re: Flywheel stuck
Hydraulic lock? Remove the glow plug and start cranking again...
Mauler is offline   Reply With Quote
Old 03-19-2002, 01:20 PM   #8
Default OOOO YAH
Yah what could be. i never thought about that good idea Mauler
OS TZ .12 Stuck at TDC theBUZZ Nitro On-Road 44 12-01-2006 06:47 PM
started my motor up....and the flywheel got stuck indy_rc Nitro On-Road 5 04-03-2006 01:09 PM
Okay, Now I'm Stuck finny Australian Racing 8 04-18-2004 07:37 PM
OS .12 tr came stuck in TDC AE Racer Nitro On-Road 19 08-15-2003 11:22 PM
Help! Flywheel Stuck!!! eBoi31 Nitro On-Road 4 04-19-2002 08:03 PM
