Old 02-16-2010, 06:35 PM   #1
BIGTACO's Avatar
Default RC Workbench Surface Coating?
I need a suggestion for a coating that I can apply to my workbench table top. This "workbench" is actually a meatmarket style cutting table. It has a super flat exposed untreated wood surface. I was going to keep the surface as is, for its superior flatness. Perfect for setting up cars...
But now I am realizing that was a pipe dream. Oils and grease and dirt are penitrating into the wood. Whats a good plastic type coating I can put on the wood surface that will repel goop but still keep a super flat surface?
RC's: MUGEN MBX5-T Prospec w/Ninja .28!
MUGEN MRX4X w/ Novarossi 321P Tuned
Trex 450 V2
RC Planes
Real Car: 2003 Corvette C5 Z06 Millenium yellow
BIGTACO is offline   Reply With Quote
Old 02-16-2010, 07:31 PM   #2
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default coating
I would try to find a clear Plexy glass to cover the whole thing
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 02-16-2010, 07:51 PM   #3
BIGTACO's Avatar
Hmm good idea but I need a material or top coat that I can beat on without cracking it...
Trex 450 V2
RC Planes
Old 02-16-2010, 07:57 PM   #4
Trader Rating: 19 (100%+)
theres no way you are going to crack plexi glass. i have used it for years and never had a problem
-Mark Cooper
minicoop is offline   Reply With Quote
Old 02-16-2010, 07:59 PM   #5
Default coating
I bought this white plastic sheet at lowes to level my pool table I think its 1/8 inch think but if you go with thicker plexy it will not break
Old 02-16-2010, 08:05 PM   #6
Trader Rating: 10 (92%+)
that is a sick work area. im jealous lol
but i would try like lacquer and apply slowly with a squeegy so theres no air bubbles and it would be a really thin, clean, and super level coating. do a couple coats like that and it should work out good.
mattjay is offline   Reply With Quote
Old 02-16-2010, 08:19 PM   #7
-TC5racer-'s Avatar
Trader Rating: 40 (100%+)
The stuff they use for skating rinks is called "Lacquerthane" lays real flat and as you all know hard as a rock. i think Lowes or the depot should carry it.
-TC5racer- is offline   Reply With Quote
Old 02-17-2010, 03:33 AM   #8
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
Default Work Bench
For the assembly side I just use 2 towels, i have found this to be best as it stops things rolling around all over the place etc. It marks up over time of course but if you wash the towels between rebuilds you always start clean. The other thing that helps is if you can lay things out, i.e the Hudy setup board has a place on the bench etc, just makes things easy..
For the machining side I actually painted the bench top (not in this photo)...
Was the worst thing I have done, it marks up, has marks all over it now, and generally "pisses" me off everytime I go in there!!.
Im going to bite the bullet when I get some time and just go with a stainless top once and for all..... I will probably do this for the assembly side as well, but put some sort of "black" rubber mat in the center of the work space.
Regards
Kyle
RC Workbench Surface Coating?-assembly-bench.jpg   RC Workbench Surface Coating?-machining-bench.jpg   RC Workbench Surface Coating?-machining-bench-2.jpg
ARC R8 RB - Blitz Kronos Tyres - Futaba
Kyle Hazell is offline   Reply With Quote
Old 02-17-2010, 04:37 AM   #9
Pattojnr's Avatar
Regards
Kyle
you have the most important thing on your bench Kyle, the Beer.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 02-17-2010, 05:13 AM   #10
RCAKid's Avatar
put on a roll on bed liner to the surface that will work good
sponsors
Murnan Modified Motors- RbM3
Rc America- Nt1
Mom & Dad
RCAKid is offline   Reply With Quote
Old 02-17-2010, 08:23 AM   #11
asw7576's Avatar
White cloth and Table Glass ( 10 mm glass )
Safe for soldering ( heat resistant ) and charging battery ( fire resistant )
Easy to clean.
Flat surface for Hudying.
.... and you can wipe off your hand to white cloth
Old 02-17-2010, 09:51 AM   #12
YBSLOW's Avatar
Use the epoxy paint like you use for a garage floor. That is what I used on my shop floor and maple countertops in my shop.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
