Old 03-14-2002, 09:11 AM   #1
carpet_killa's Avatar
Kawahara brake disk ?
is there a certain way you put this on the 2 speed in between the break pads. or doe it matter , i am woundering if the cross drilled holes turn twards the engine or twards the rear of the car. which is the better way? thanks guys.
carpet_killa is offline   Reply With Quote
Old 03-14-2002, 09:40 AM   #2
Send a message via AIM to VinDollar Send a message via Yahoo to VinDollar
Default Re: Kawahara brake disk ?
I put my cross drilled holes towards the engine in that direction. I just went by how it's on a 1/1 car. I really don't think it matters though. On the subject of the two speed, i don't think that the disk and everythng fits the way it did with the stock pieces. It has a little more play overall. At this moment i didn't experience a problem with that.
VinDollar is offline   Reply With Quote
Old 03-14-2002, 10:30 AM   #3
Default re:
thanks vin. i appreciate it. thats how i was putting it on but i wanted to wait before i put the rest together though. hey did you ever fix it where i and everone else could view your mtx2 ? there is still a code thing it is asking for. thanks again.
chris
Old 03-14-2002, 10:32 AM   #4
Default Re: re:
chris
I actually didn't but i will post a new pic up soon linked to a new host
Old 03-14-2002, 09:42 PM   #5
fraz's Avatar
Send a message via AIM to fraz
Chris,
I have been running the Kawahara rotors since RCI started bringing them in and I run it the same way stated. Does it make a bit of difference? I doubt it.
The only reason I do it this way is because I am use to my 235mm car and my MRX-3 where there are 2 steel rotors and an aluminum impeller/cooler in between. In that application, you always point the scops toward the direction of rotation (toward the front of the car) to draw air into the center.
Another tip on the Kawahara rotor is that the holes will wear out faster than the stock rotor because it is thinner than the stock one. The 3 holes on the pulley adaptor hog out the rotor and make it rather sloppy after a while. The good news is there is another set of 3 holes to get more life out of it.
fraz is offline   Reply With Quote
Old 03-15-2002, 12:36 AM   #6
Default RE:
thank you fraz ! that helps alot.....
RC8 brake disk slop? Allumina Nitro Off-Road 4 07-26-2008 09:24 PM
Orion V2 19T - Savage Hopup - RC10GT Brake disk - Speed Gem motor mbunker R/C Items: For Sale/Trade 9 06-07-2007 12:19 PM
Kawahara MTX3/4 M426 Vented Brake Disk cvccsi R/C Items: For Sale/Trade 0 05-20-2007 10:30 PM
WTB Savage dual disk brake set up Jon2 R/C Items: Wanted to Buy 0 09-24-2006 02:54 PM
Kyosho V ONE RRR East Racing Brake Disk cvccsi R/C Items: For Sale/Trade 0 04-28-2005 01:26 PM
