LiFe rx pack?
#31
Just get one of those and get it over with.
Excellent charger, which covers all nitro racer's needs and much more
http://cgi.ebay.com/Imax-b6-Lipo-bat...item2eab865d2b
My friend told me that in an ETS race, he saw Martin Hudy using one of these!!!
I want to ask you guys though, why do you use Life or lipo instead of Nimh? I use lipo in my transmitter and starterbox, but in my car I use Nimh packs and never have a problem.
#32
This charger is the same as Turnigy or GT power chargers, inside of them are completely same, and yes, its more than enough for nitro racers. Im also driving an electric touring car, and charging my lipos with this charger.
#33
For me, 2 things:
- Weight, 125gr. NiMh compared to 72gr. LiFe
- Less voltage drop under load...
Ok, and maybe because I like to go with something new, so once and a while.....
#34
#35
I use lipo in my radio because I also use it in computer games, so runtime is important. And its 3PK, so heavy...
Lipo in my starterbox because lead acid batteries are way too heavy and they dont last long. In addition, starterbox with lipo turns new engines easy.
Less voltage drop and longer runtime sounds nice but I would consider putting life in my car only if my car was too heavy but Im already underweight with stock Capricorn, so can not afford being another 60gram lighter.
#36
http://www.rc-mushroom.com/product_i...ducts_id=15217
LiFe:
http://www.rc-mushroom.com/product_i...ducts_id=18240
$4 difference....
LiFe has no safety issues like LiPo, and we are also talking 1450mAh, not 5000.....
But NiMh is perfect for Rx, don't get me wrong.
I could loose some weight on my car, then LiFe is a good option.
1 more remark, if you know the theory behind electro, you know that with my remark on the previous page you will get more runtime with LiFe, compared to NiMh, why?
Because the voltage drops more with NiMh then with LiFe, the servo's will draw more current to have the same power output, so a 1600mAh NiMh will have less runtime then a 1600mAh LiFe....
#37
ive got the ip 1450 life, and unlike nihm no memory effect and hold its charge over time w/o use, got the hobbyking eco6 charger at $20 w/0 shipping from hobbyking.com , charges all my lipo life lead acid and nihm and glow starter w/o any issues so far! can beat that price and performance, and i use my laptop charger as power supply btw! and i also got a 2 swire extension so to balance my life rx pack without removing the battery tray, also from hobbyking!
#38
i have a question for you guys. i asked this on another thred before seeing this one. what is a good li-fe rx pack to buy. ive seen the ip but what about some others that have been used. thanks.
#39
http://www.lrp.cc/en/products/vtec-b...y-66v/details/
#40
Hyperion also makes 2s LiFe packs in a few different configurations. When looking at the package it has a 5c rating on the front. That's nothing if it was the discharge C rating but it's not. Hyperion claims, a balance charge rate of 5c. The discharge C rating is 25c.
#42
NiMh:
LiFe:
$4 difference....
LiFe:
$4 difference....
http://www.rc-toro.com/product_info....71369824efd988
I never had any incidents of it. Even I don't use a lipo bag, I feel safe about it. It is very low voltage and small capacity, so the energy burst is not very great (not like the 14.8V 5000mah+ battery).
The key here is to get a good charger, so your battery will get cut off properly. All the incidents I heard are related to overcharging. In such case, it really doesn't matter what kind of batteries. There is always a safety hazard.
#45
Where did you buy the cells?
Regards
Regards
