Old 02-09-2010, 09:36 PM   #1
92GTA's Avatar
Default Clutch setup - What am I doing wrong?
I gave an OS engine I'm putting in my RRR and I have done the following:
#1 - Install the shim and flywheel collet onto the crankshaft. Depending on your engine and collet you may have to use a shim so the flywheel doesn't drag on the engine case. Install the flywheel and flywheel nut onto the crankshaft and tighten. Make sure it is very tight otherwise it can come loose and damaging the other clutch components as well as decrease the life of your engine.
#2 - Install the centrifugal shoes (clutch weights) into the flywheel. Make sure they are clean of any flashing or sharp edges, as this will ensure smooth and consistent clutch operation. Install the clutch shoe ring, lining up the holes with the flywheel pins.
#3 - Install the clutch shoe into the clutch shoe ring, lining up the holes with the flywheel pins. The clutch shoe and shoe ring should move freely up and down on the flywheel pins. If they don't, use the proper size drill or very carefully use a hobby knife to remove a small amount of material from the shoe. Usually, some material needs to be removed from the flywheel pinholes in the clutch shoe – it doesn't take much so be careful not to remove too much material!!
#4 - Install the spring cup into the clutch shoe making sure it is seated all the way. Install the clutch spring and the clutch spring adjuster. Tighten it down so that about .5mm of thread is showing. This will be our assembly setting, as we will do the final adjustment later.
#5 - Install the pinion gears onto the clutch bell and tighten them. Do not over tighten them or it will be extremely difficult to get them off later.
The basics of your clutch are assembled now and this is where the set-up comes into play. How you build and set your clutch will be a key to improving your lap times.
#6 - First, we will set the “gap”. The “gap” is the distance between the clutch shoe and the clutch bell when it is at its farthest position from the shoe as possible. Install the clutch bell onto the crankshaft without the inner bearing – this will allow the clutch bell to make contact with the shoe without the bearing stopping it. Now, install the outer bearing, thrust assembly (including thrust retainer) and the 3mm screw. Tighten the screw down and check the clutch bell. There should be plenty of endplay that will give us the room to shim the “gap” properly.
Now my problem: I have no gap! The clutch bell is tight down onto the clutch shoe!
Does this mean I have the wrong collet maybe? Should I have not used a shim between the collet and the flywheel? I'm using the longer 3x15mm screw even. I can't possibly imagine the gap between the flywheel and the crankcase being any less lol!
Any ideas?!
Thanks!
http://www.TheFOAT.com/92GTA
Kyosho V-One RRR "Shimo Edition"/Pagani Zonda Body
O.S. .18 TZ(P) Turbo w/11K Slide Carb/O.S. T-1040 Pipe
Futaba BLS451 Digital Brushless High Torque/Speed Servos
Futaba 3PM-X 3-Channel 2.4Ghz FASST Radio System w/R603FF Receiver
92GTA is offline   Reply With Quote
Old 02-09-2010, 09:53 PM   #2
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Do not use the shim between the engine and flywheel.
There should be minimal gap between your engine bearing and flywheel (as long as they don't touch).
When you remove this shim, and re-install it, if you still do not have enough gap to play with, you will need to either use a different collet or do what I do with most of my engines and sand down a few mill off the existing collet.
See attached document for clutch setup....
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-09-2010, 10:00 PM   #3
asw7576's Avatar
Any ideas?!
Thanks!
Perhaps this is new flywheel, and the flywheel is not deeply seated ( or inserted ) into crankshaft. That's why you encounter no clutch gap at the tip of crankshaft.
Try drop some oil in flywheel's inner hole, collet, and locknut before tightening the locknut. The oil helps to lubricate the flywheel when it is being inserted into crankshaft.
2nd solution, you add small 1mm thick shims at the very tip of crankshaft ( you make the tip longer ).
3rd solution, use shorter colllet, I think this is your problem. What engine do you use ?
Old 02-09-2010, 10:05 PM   #4
rmdhawaii's Avatar
If he is not using a washer, it could very well be a collet length problem. I've had this problem with the RRR before. I ended up having to shorten the collect myself.
How much does the collect stick out of the back of the flywheel?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 02-09-2010, 10:08 PM   #5
92GTA's Avatar
I can't see the collet sticking out the back at all, the flywheel is as far back as it can b right up against crankcase seal I think. I can still remove the 1 shim from between the collet and the crankcase and see if it still does not touch but I don't think that will be enough.
EDIT: I removed the shim that was behind the collet and redid everything and still haven no play. I guess I'll grind down the collet a bit. Should I grind it from the bigger side?
I put the collet in the flywheel off the engine to see how far it sticks out the back, it less than 1/10th of a mm, it sticks out the same thickness as the smallest shim lol. Not much to grind off lol.
Any ideas?
Old 02-09-2010, 10:28 PM   #6
Since no one mentioned this, you should check manual to make sure the collect you are usins is for the type of engine you have. Does your engine have a threaded shaft or is it smooth like an sg enging. some kits come with two collects to accomodate the different types.
Check to see that you have the right one. My very first kit had this and it gave me fits till I re-read manual and saw I had the wrong collect on.
Kyo83 is offline   Reply With Quote
Old 02-09-2010, 10:38 PM   #7
rmdhawaii's Avatar
Any ideas?
Don't grind any material off the collect. You're probably at the minimum.
I have done asw7576's 2nd solution, add shims to the end of the crankshaft, but that was not the most ideal solution. You might want to try it just to see how many millimeters you need to lift the clutch bell off of the clutch shoe.
Edit: millimeters/fraction of a millimeter you need...
Old 02-09-2010, 11:36 PM   #8
spurgear's Avatar
Send a message via MSN to spurgear
This might be an overlooked problem but did u install the Clutch weights the correct way? A friend of mines recently had the same problem as urself installing a 18tz in his 733. All this time he had the tapered side to the flywheel facing away.
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 02-10-2010, 03:58 AM   #9
asw7576's Avatar
Can you take some photos ?
I want to see how did you assemble the clutch
My collet ( if I remeber corectly ) is 5mm - 6mm long. ( mugen seiki collet ).
Old 02-10-2010, 04:01 AM   #10
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
+ YouTube Video
works everytime i use this tip, and works well.....
Enjoy
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 02-10-2010, 07:13 AM   #11
92GTA's Avatar
Watching the video cleared things up for me! I was still putting the outer bearing on the bell under the thrust bearing and only leaving out the inside bearing and shims. Looks like I leave out BOTH bearing and only use the thrust bearing.
When I go home tonight I'll do it like the video and I should have no problem.
EDIT: I also just noticed that he puts BOTH bearings under the bell with only the thrust bearing at the end. I was putting the big bearing at the end under the thrust bearing and leaving out the small bearing which I thought was the only one that went under the bell. Wow, I totally needed to watch that lol.
Old 02-10-2010, 08:36 AM   #12
rmdhawaii's Avatar
That's a different car - not a RRR.
Old 02-10-2010, 08:42 AM   #13
rmdhawaii's Avatar
Here are all the instructions for the RRR series... Take a look at the Evo2 instructions at the bottom - pages 44 & 45.
http://www.kyosho.com/eng/support/in...one_index.html
Old 02-10-2010, 08:46 AM   #14
92GTA's Avatar
Yeah I followed my manual and it told me to put the small bearing inside the bell, the large bearing on the end of the bell with the thrust bearing on it under the screw at the end. That's where I got confused. So I guess just because it's the same clutch type means they don't all go together the same way? So by following the RRR instructions I still have the same problem I did lol.
Old 02-10-2010, 09:13 AM   #15
staikosn1's Avatar
Send a message via MSN to staikosn1
Nice tip...
Ill use that in near future....
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
I AM CLEANING OUT EVERYTHING!!!! OneBadFirstGen R/C Items: For Sale/Trade 34 02-24-2011 09:16 PM
Need clutch advice bjr48 Nitro Off-Road 20 12-08-2008 04:37 PM
