Old 02-10-2010, 09:49 AM   #16
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by 92GTA View Post
Yeah I followed my manual and it told me to put the small bearing inside the bell, the large bearing on the end of the bell with the thrust bearing on it under the screw at the end. That's where I got confused. So I guess just because it's the same clutch type means they don't all go together the same way? So by following the RRR instructions I still have the same problem I did lol.
I have a Shimo kit and instruction manual. It says to put the larger bearing (5x10x4) on the side of the clutch bell closer to the engine. The smaller (5x8x2.5) bearing goes on the outside with the thrust bearing.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-10-2010, 04:47 PM   #17
92GTA's Avatar
HA! That was it! I was simply getting the 2 bearing reversed! I have it together perfectly now! Thank you!
http://www.TheFOAT.com/92GTA
Kyosho V-One RRR "Shimo Edition"/Pagani Zonda Body
O.S. .18 TZ(P) Turbo w/11K Slide Carb/O.S. T-1040 Pipe
Futaba BLS451 Digital Brushless High Torque/Speed Servos
Futaba 3PM-X 3-Channel 2.4Ghz FASST Radio System w/R603FF Receiver
92GTA is offline   Reply With Quote
Old 02-10-2010, 05:57 PM   #18
spurgear's Avatar
Send a message via MSN to spurgear
good to know u sorted this out!
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 02-10-2010, 06:40 PM   #19
92GTA's Avatar
Thanks! Once I receive and install my new servo horns tomorrow I'll be ready to fire her up! I'm totally stoked!
Old 02-16-2013, 06:32 PM   #20
snuvet75's Avatar
Trader Rating: 16 (94%+)
I'm having the same problem here. I just got X-ray NT1 '12 and O.S. 12XZ ABC engine. Built the clutch as directed in manual and there's no clutch gap at all. Actually I got this car and engine from somebody else and he had already built the car with engine. I disassembled it shortly after engine breaking in(it was never run) because the wheels would not run while the engine was running just fine. So I figured maybe the preload was too tight but that was not the problem. So I built the clutch again and everything seemed to have been built fine. After ruling out one by one, I came to a conclusion that it's got to be the flywheel collet(collar). The guy used 5mm long collet and there was another in a bag which was 7mm.
It seems that I'm supposed to use 6mm collet instead according to x-ray's recommendation but not 100% sure because I don't know if O.S. engines are Picco or Novarossi type. I'm a electric guy and this is my first nitro car lol. Some help here please? I'm going to order 6mm collet anyway in the mean time.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is online now   Reply With Quote
Old 02-16-2013, 06:34 PM   #21
snuvet75's Avatar
And Team X ray has their own recommended collets. So does this mean that I can't use any other collet from different companies??
Old 02-16-2013, 08:54 PM   #22
blis's Avatar
Use a longer thrust bearing retainer!
http://www.rcmanufactory.com/prodimg/K14133-3.jpg
Like one of these. Take a measuement of your existing one's length and get one slightly longer. Alternately you could just shim out the retainer between the crank with small shims, but they are a pain and u lose them when servicing the clutch.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 02-16-2013, 08:56 PM   #23
blis's Avatar
If the collet's angle suits the flywheel and doesnt protrude inside its good. If it is too long a cone it wont let you tighten the flywheel.
PS: I've sat my fair amount of timein front of a wetstone grinding my collets, with patience there's nothing to really get worked up about, ensure it's ground evenly and it's all good. The gap bewteen the engine's block (or front bearing) and the flywheel is quite small nowadays, taking note, I have many collets that are just too long for my clutches.
PPS: It wouldnt hurt to get the correct collets for your kit's clutch.
Old 02-17-2013, 02:42 AM   #24
Roelof's Avatar
Send a message via ICQ to Roelof
One tip. Before installing the flywheel, just make a hard pull on the crankshaft and be sure the collar is pushed against the bearing while pulling on the crankshaft. Sometimes the crankshaft is pushed in taking away some tenths of a mm from the gap.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-24-2013, 11:07 PM   #25
snuvet75's Avatar
I know this posting is more than 2 y old but I have exactly same problem. I don't know how exactly this guy solved the problem(he jumbles around in his explanation). But my Xray NT1 2012 with O.S. engine had exactly same problem. No shim behind flywheel for sure. Still no gap when I put together everything. I ended up putting a shim at the end of crankshaft to lengthen the shaft itself. I was lucky to have a shim with exactly same diameter as the crankshaft. IMO, grinding collet is dumbest thought ever. Buy a correct one if you have time to do that. As far as collet fits right onto crankshaft and doesn't stick out of the flywheel when you tighten it all the way(if it sticks out, you can't tighten the flywheel anyway), it doesn't matter what brand of collet you use. It's just that finding correct collet can be hard.
Old 02-25-2013, 02:01 AM   #26
djiewie's Avatar
Xray has clear instructions on how to do it. But it can be difficult. What Roelof said about pulling the crankshaft is something one can easy forget. This will not resolve just by thightening the nut. And a 9,1 mm shaft protruding when you have the flywheel with nut on is a quick check. Still the bearing retainer with the thrustbearing have differant lengths so this is important also. But with 9,1 mm checked you know its the bearing retainer wich needs to be longer. Hope this info helps you.
djiewie is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
I AM CLEANING OUT EVERYTHING!!!! OneBadFirstGen R/C Items: For Sale/Trade 34 02-24-2011 09:16 PM
Need clutch advice bjr48 Nitro Off-Road 20 12-08-2008 04:37 PM
