Old 02-07-2010, 12:43 AM   #1
wmay11's Avatar
Default .21 Shimming
Hey guys, I recently got hold of some JP engines and see that they are shimmmed underneath the sleeve, ie. between crankcase and sleeve. Is this to increase RPM or torque. What head clearences are suited for NR engines I am running at about .7 on the coast.
Thank you
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 02-07-2010, 02:01 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
The real clearance can be messured by sqeezing a tip of solder between the head and piston turning it through TDC, that must be arround 0.6 to 0.7 mm
Less will give more bottom torque more will give a slight better RPM
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-07-2010, 02:46 AM   #3
wmay11's Avatar
Ok, but what does the shimming under the sleeve do? Does it increase the timing and therfore increase RPM?
Old 02-07-2010, 05:51 AM   #4
Roelof's Avatar
Shims under the sleeve is a standard trick to raise the ports without grinding, I have seen it before with JP team engines.
It will give a longer opening on the intake (more fuel) and the higher exhaust will give a fraction more RPM.
When taking away the milage and bottom power should be bettered. But be sure when taking away you do need to add the same size shim extra under the head. (lowering the sleeve will lower the head and so making the head clearance smaller)
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 09:40 PM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 06:30 PM
Jammin JPX.21 engine Quad Racer 34 Nitro Off-Road 6 08-16-2009 11:18 PM
jammin .21 shimming slayyer Nitro Off-Road 14 08-02-2009 11:21 AM
