Old 02-05-2010, 11:47 PM   #1
92GTA's Avatar
Default Kyosho RRR, common to be missing parts?
As I'm building my Shimo Edition I have come across 4 missing pieces:
They are on page 23, step 24, the adjustable stabilizer.
2 adjustable rods and 2 shock ends.
Bag 8 only had 2 adjustable rods total and 2 shock ends total instead of 4 of EACH so I can't complete step 24 since the ones I did have were used on step 22.
Is this common? Should I contact the place I bought the kit from?
Thanks!
http://www.TheFOAT.com/92GTA
Kyosho V-One RRR "Shimo Edition"/Pagani Zonda Body
O.S. .18 TZ(P) Turbo w/11K Slide Carb/O.S. T-1040 Pipe
Futaba BLS451 Digital Brushless High Torque/Speed Servos
Futaba 3PM-X 3-Channel 2.4Ghz FASST Radio System w/R603FF Receiver
92GTA is offline   Reply With Quote
Old 02-06-2010, 12:07 AM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Thanks!
There are only supposed to be two of each. 2 shock ends (the hole goes all the way through). That end snaps over the round end of the rear stabalizer bar. 2 ball ends/cups (That end goes onto the ball stud in the rear a-arm)
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-06-2010, 12:33 PM   #3
92GTA's Avatar
Originally Posted by Scott Fisher View Post
There are only supposed to be two of each. 2 shock ends (the hole goes all the way through). That end snaps over the round end of the rear stabilizer bar. 2 ball ends/cups (That end goes onto the ball stud in the rear a-arm)
Half correct, I think. I did those but now there are supposed to be more to connect from the other ball studs on the rear a-arms to the adjustable rear stabilizer (in addition to the regular stabilizer bar you mentioned). That means 2 MORE adjustable rods, 2 MORE shock ends. I have the other 2 ball cups.
EDIT: OMFG, I'm such a newb LMAO! I *thought* pieces were missing because I didn't understand that you CHOOSE between which types of stabilizer bars to use, not have both installed at the same time OH:
