MUGEN SEIKI MRX5 >
MUGEN SEIKI MRX5
Like Tree3Likes
MUGEN SEIKI MRX5
Old 02-02-2011, 05:32 AM
  #1471
MugenDrew's Avatar
Trader Rating: 36 (100%+)
The front one way bearing insert can be locked down by adding a wipe or two of super glue to the area of the front upper bulkhead where the two pieces make contact. Just be sure you let the glue dry before you put it on.
Tweak. Check the stuff Ralph mentioned, in addition clearence the radio box with a dremel and make sure your battery is not making contact with the back of the fuel tank sump.
Radio stuff Ive found. Remove your radio/servo bracket and look very closely at the head of the front lower steering servo mounting screw and the rear edge of the front lower bulk head. There may not be contact with the car at rest, but I keep finding "glitching cars" with these area's polished from contact. The other issue I have seen is the screw that runs thru the brake linkage slider that threads thru the deck mounted throttle/brake horn gets set up corectly with play to allow smooth movement. However when the link to the servo horn gets attached the piviot ball is over tightened and while running it will pull the threads in the deck mounted arm and put the hole enchilada in a bind, servo amp draw goes thru the roof and the reciever freaks out...
MugenDrew is offline
Old 02-03-2011, 03:29 AM
  #1472
occ
Trader Rating: 16 (100%+)
New radio tray for the MRX5.
Receiver moved to the exhaust side.
occ is offline
Old 02-03-2011, 04:04 AM
  #1473
choisan's Avatar
i am expecting to see the fix of the front knuckle
choisan is offline
Old 02-03-2011, 04:44 AM
  #1474
X4
X4's Avatar
Is that MTX5 or MRX5??
X4 is offline
Old 02-03-2011, 05:07 AM
  #1475
choisan's Avatar
mrx5
choisan is offline
Old 02-03-2011, 08:25 AM
  #1476
T-BODZ Terry B.'s Avatar
Thumbs up
When I assembled mine back in October before the Regionals, I noticed the slack in
the side belt and just added an additional Addjustable Belt Tensioner / YBSlow!
Worked just fine with no issues....
Attached Thumbnails MUGEN SEIKI MRX5-dsc03493.jpg   MUGEN SEIKI MRX5-dsc03495.jpg   MUGEN SEIKI MRX5-dsc03498.jpg
T-BODZ Terry B. is offline
Old 02-03-2011, 02:21 PM
  #1477
walo's Avatar
Nice , I still believe the original set-up without another tensioner will work. After I built mine, the tension on my belts seem fine. It took a little time to adjust it to the way I like my belts to feel. Nevertheless, I'm sure when I take it out for an official spin everything will hold up .
walo is offline
Old 02-03-2011, 02:28 PM
  #1478
Phil Trotta's Avatar
+1 walo i ran the stock set up it was fine i was bored one day tinkering when i made the extra tensioner .................................................. .......walo new car....new motors...you are on the right path to have a real good season...........................................s ee you soon...
Phil Trotta is offline
Old 02-03-2011, 02:32 PM
  #1479
walo's Avatar
What's up Phil? I saw some of the track lay outs you have planned. There are on the money .
walo is offline
Old 02-03-2011, 02:37 PM
  #1480
yeah they were just some ideas to ralphie but i dont wanna get involved in that.........what ever gets done will be fine......i just race and keep nyrc live growing.....all the track stuff is ralphie/richie.........we got a lot of racing in chaplin too with the nationals....regionals ....and novarossi race....
you gonna love the car...
Old 02-03-2011, 02:54 PM
  #1481
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
theres also an XRay race at Chaplin this season
Serpent-Dan is offline
Old 02-03-2011, 07:08 PM
  #1482
YLLIB's Avatar
There will be a new belt out real soon guys for the car..
YLLIB is offline
Old 02-03-2011, 08:10 PM
  #1483
bsmooth's Avatar
Will there be a trade-in program for the old belts?
Just kidding!!
bsmooth is offline
Old 02-03-2011, 09:10 PM
  #1484
YLLIB's Avatar
Talking
Just kidding!!
your not kidding, You might have well said that about your MRX-5 that probably won't hit the track at least until next year 2012, LMAO. I guess that's why you call yourself be smooth, until you hit the track, then we can call you bruff.......LMAO
YLLIB is offline
Old 02-03-2011, 09:27 PM
  #1485
West03's Avatar
Who on here is going to the world? Did anyone whom post on here regularly raced at the pre-worlds? I have some questions?
1. How is the tire wear on the homestead circuit. What shores where mainly used?
2. Did anyone get a chance to see if, Pietsch, Swauger, Fukuda, Rick V or anyone else use the floating or fixed radio option.
3. Did anyone get the setup sheets from the front running Mugen drivers.
P.S Any inside will be a great help for us drivers going to Homestead for the first time. Thanks.
West03 is offline
