MUGEN SEIKI MRX5 >
MUGEN SEIKI MRX5
Like Tree3Likes
MUGEN SEIKI MRX5
Old 10-07-2010, 09:43 AM
  #781
ralphierace13's Avatar
Originally Posted by wingracer
From what I understand, the rear is the same but front and side are different.
just go to mugen web site u can open the instruction book get all the info u need...
ralphierace13 is offline
Old 10-07-2010, 04:12 PM
  #782
mugenize1's Avatar
My browser is not allowing me to open it can someone post it for me please
Thanks,
mugenize1 is offline
Old 10-07-2010, 04:46 PM
  #783
tdr170's Avatar
Thanks,
The file is in PDF format make sure you have Adobe reader if you do not go to http://get.adobe.com/reader/ and install it you then should be able to read it.
You can also save the file to your hard drive for faster load and to have on hand.
Mugen MRX4X - Novarossi
tdr170 is offline
Old 10-07-2010, 07:57 PM
  #784
rcmike's Avatar
Trader Rating: 40 (100%+)
i ran a life today was great no problems 6.6 1450..
Originally Posted by Grenade10
I've run a life pack in my MRX-4x for the whole season. 1450ma and have worked without any issues. I purchased 2, but probably could have done it with one.
Thanks, I have 2 life now just in case.
rcmike is offline
Old 10-08-2010, 03:53 AM
  #785
hey just just alittle tip rear lower arm holder b the top screws above the plastic inserts that hold the lower arm pins in use a 1mm shimm not a thrust bearing shim find a shim with a 3mm hole so it fits right onto the sig3x6 screw but is larger then the button head this will insure the plastic caps do not vibrate loose and cause the lower pins to come loose.....
Old 10-09-2010, 07:33 AM
  #786
mugenize1's Avatar
What are the steering rod mm for the MRX5 are they 57mm?
Oh I can not download the manual so can someone help please Thanks,
Old 10-09-2010, 10:25 AM
  #787
85.8 on the steering rod on the servo saver rod its 39 just go to adobe its free to download the adobe reader... important to have
Old 10-10-2010, 07:28 AM
  #788
mugenize1's Avatar
I got it. My computer was giving me a hard time but I got it now thank you so much.
Old 10-10-2010, 07:37 AM
  #789
mugenize1's Avatar
No your info is not correct 85.8mm is from ball-end to ball-end. What is the mm on the rod only? also the manual does not tell me what are the pulley teeth on the rear are. Not the rear axle
Old 10-10-2010, 05:35 PM
  #790
i
jrice is offline
Old 10-10-2010, 05:40 PM
  #791
MRX5 TAKE 1st and 2nd AT FORGASS RACE # 2 at the "FORT"
Sean lue and Tony Rice finish one ,two
new car is great !!!!!!!!
jrice is offline
Old 10-10-2010, 06:17 PM
  #792
Every MRX 5 entered at the FORGASS race at Ft Myers finished in either the A or B main
The new car was very easy to drive.
CFowler is offline
Old 10-10-2010, 06:25 PM
  #793
Tony Rice's Avatar
Default MRX-5 Gets Results
Florida State Series Race number 2 in Fort Myers, FL.
The first outing for many with the new car. I ran my fastest qualifier ever.
6 out of the 10 A Main cars were MRX-5.
1 MRX-4X
3 other cars
Attached is the podium photo and a some of the Mugen racers at the race.
Monday night goto forgass.com for results and photos.
Attached Thumbnails MUGEN SEIKI MRX5-mugen-finishers.jpg   MUGEN SEIKI MRX5-team-mugen-forgass-10_10.jpg
Tony Rice is offline
Old 10-10-2010, 06:35 PM
  #794
YBSLOW's Avatar
Default MRX5
We have the brass battery tray in stock now. I will add it to the website tomorrow. We will have the Billet Delrin front body mount by the end of the week and more to follow.
YBSLOW is offline
Old 10-10-2010, 07:55 PM
  #795
It was over 90 degs. today at the track. Can,t wait for it to cool off
to see how fast the track gets .next race at Kraceway.
IF YOU ARE THINKING ABOUT GETTING THIS CAR, DON.T WAIT !!!
Order it today.
I tested it today when i had a receiver go bad.
Left pit road wide open into the sweeper wall. Lost the engine,but only broke the lower right a-arm on the car.
If you have ever been to the "FORT" you know about the walls . they don,t move.
Mugen you have a WINNER
jrice is offline
