Old 02-02-2010, 11:30 AM   #1
BIGTACO's Avatar
Default Pinion(s) position problem on Serpent 733
I have a Serpent 733. I installed my motor last night "Sirio Evo 4", and noticed a problem. No matter what I do I cannot get the pinions on the centax bell to line up correctly with the first and second gear spurs. The pinions stick out past the spurs by about a full millimeter when the bell is up against the thrust bearing, like it will be when the shoe is pressing the pressure plate, under acceleration.
The stock 733 motor mount is machined to allow only for front and rear positioning of the motor. It will not allow for right or left. Which is silly.
I have double checked my centax assembly to make sure everything is to spec, and its right on! I have even shimmed out the spurs somewhat to try and make up for the built in slop there. I could drill out the motor holes or the mount but would rather not. Is this normal? Has anyone else had this problem?
RC's: MUGEN MBX5-T Prospec w/Ninja .28!
MUGEN MRX4X w/ Novarossi 321P Tuned
Trex 450 V2
RC Planes
Real Car: 2003 Corvette C5 Z06 Millenium yellow
BIGTACO is offline   Reply With Quote
Old 02-02-2010, 11:35 AM   #2
Doug M's Avatar
Sirio crankcases are different than the other majors, You will need the Sirio mount.
http://www.serpent.com/product/804189
Doug M is offline   Reply With Quote
Old 02-02-2010, 11:57 AM   #3
BIGTACO's Avatar
Doug you sir are a gentleman and a scholar.
Trex 450 V2
RC Planes
