Old 01-31-2010, 10:43 AM   #1
Default help with os .18cv-rx in a hpi rs4 evo
the crank shaft doesnt have a hole in the end to secure the clutch bell how do i proceed
gestruction is offline   Reply With Quote
Old 01-31-2010, 05:00 PM   #2
wizby's Avatar
So what is on the crank end? Threads? Slot? Is the end boken off? Is there screw broken off in the hole? What crank was on the old engine? SG, threaded? Who sold you the engine and said it would work in your car?
XRAY NT1 2014 NOVA KEEPON DX3R
MIKE PARKER PRESIDENT
NORTHERN INDIANA TEAM RACING ORG. MIDWEST SERIES TEAM DIRECTOR
wizby is offline   Reply With Quote
Old 01-31-2010, 06:44 PM   #3
Default os.18cv-rx to hpi
engine is new in the box it was brought at tower hobbies they told me to try this forum 4 help.it has threads and a screw the original engine has a hole in the crank shaft.when i look on os site it shows the engine in an hpi but it doesnt show how the clutch bell is secured. thanks in advance for your help
Old 01-31-2010, 07:04 PM   #4
Unhappy os.18cv-rx to hpi
Old 01-31-2010, 07:21 PM   #5
wizby's Avatar
Exactly what engine did you buy. Tower part number would help. Did the packageing or the web site say anything about it being a SG type shaft?
Old 01-31-2010, 07:51 PM   #6
Default tower part #osmg2104
on towers site if you look at the hpi rs4 evo it even list the engine as a upgrade near the bottom of the page
Old 01-31-2010, 08:39 PM   #7
clod_fan_101's Avatar
Trader Rating: 51 (100%+)
Default different engines
hello
there is a lot of different engine setup's out there . if there isnt a hole in the center of the crank for a screw then there should be a notch in the shaft for a e-clip towards the end .
hope that helps
here is a pic of some small engines , hopefully you can see the notch in the one on the left
thanks
austin powers # 1 fan
clod_fan_101 is offline   Reply With Quote
Old 01-31-2010, 08:48 PM   #8
Default your engine should look like this
if so there is usually a shaft that you screw on to secure the fly wheel , the shaft should have a notch at the end to secure a e-clip to the end so you can secure the clutch bell to it
let me know
now i m curious
thanks
Old 01-31-2010, 09:18 PM   #9
Smile thanks thanks thanks
thats the missing part to my puzzle a c clip
Old 01-31-2010, 10:14 PM   #10
Default glad
to have help
thanks
Old 03-14-2010, 05:53 AM   #11
Trader Rating: 55 (100%+)
I don't know if u figured it oug yet but when u take out the old engine you have to remove the screw that holds the flywheel in place once u take that off you will be able to use the same screw on the new engine to secure the flywheel as well as the clutch bell.
Speedychris22 is offline   Reply With Quote
