Old 01-18-2012, 08:14 PM   #1321
Just received my new lab co2 kit from kamikaze hobbies.Does anyone know if the acer ceramic bearing kit for the co1 will fit the lab co2?
brettoakland is offline   Reply With Quote
Old 01-19-2012, 01:12 AM   #1322
Chickentrader's Avatar
The front diff's bearings are different, but the rest will fit. Just remember that the CO2 has additional 3x6x2.5 flanged bearings (no need for ceramics) and 5x10x4 bearings for the side belt tensioner.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 01-19-2012, 11:36 AM   #1323
BELL CLUTCH 1/10 ERGAL with black shoe How long does it last compare to the stock ??
jorge858 is offline   Reply With Quote
Old 01-19-2012, 04:12 PM   #1324
Default One way busted :(
Hey people so last Subday was running my C02 and all of a sudden engine break. 1st spear gear stripped 360 degrees. Today started the inspection as I thought the engine moved and to my big surprise the one way was like welded to the shaft. Took some beating to remove shaft from one way.
Do I need to replace the shaft as well even though it still looks & feels good ?
Why did this happen when the one way was lubed with proper grease etc...
I might have degreased the one way while cleaning and forgot to lube.
speed6 is offline   Reply With Quote
Old 01-19-2012, 04:42 PM   #1325
DS Motorsport's Avatar
I advice to use the bell and shoe only for practice before race day and on race day. It will wear faster then a steel bell and a red shoe but the improved acceleration is defiantly worth it.
Also clean the bell and shoe after everyday of practice
Acer also have a LAB C02 kit available.
But as mentioned by Lars the only main difference are the new smaller front diff bearings.
If the shaft still looks good and still has a proper diameter I think you could use it again. Might clean it up a little with some soft scotch bright to be sure.
If it hasn't been lubed it will overheat and it will get stuck.
I clean mine before every practice day and when I'm running the car a lot or the track is dirty I will clean and relube during the practice day.
Most of the Capricorn one ways are German INA bearings and I think they are best lubed with an oil, I use the Xceed one way oil.
I've been using the same one-way which was in the kit in 2010 for all my practice days until the end of 2011.
I have a completely separate gearbox and one way which I only use on race days.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-20-2012, 08:48 AM   #1326
There have been rumors for a while but today it's official: Lamberto Collari has joined Capricorn!.
The best drive in the world now has the best car in the world.
We can exclusively report that 9-time World Champion Lamberto Collari has joined Capricorn for 2012. Having driven for Kyosho previously the Italian was looking for a new adventure and decided to change to Capricorn to make an Italian dream team with Italian driver, car, engine and tires. As well as competing in this year’s National championship and aiming to defend the European title he won last year in Luxembourg, Collari is also looking for new goals and having tested the company’s Lab-C02 chassis, has decided for the first time to compete in the 1/10th scale class and will race that this year’s Euros in Cassino, Italy.
Source:
http://www.redrc.net/2012/01/exclusi...ins-capricorn/
P1-RC.com
Old 01-20-2012, 10:21 AM   #1327
Stuff Of Legend's Avatar
Me Kyosho Competition Capricorn
Stuff Of Legend is offline   Reply With Quote
Old 01-20-2012, 11:58 AM   #1328
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Great addition to the team. And he'll drive a sedan too!!! Wow
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-20-2012, 05:03 PM   #1329
what the different from the WHITE eccentrical roll center to the black??
Old 01-21-2012, 01:46 AM   #1330
Just started my build of the co2.manual & pictures or the worst.My manual for my d8 hara buggy is way better&($300.00 cheaper) hardware is ok at best.fit & finish of parts is outstanding. Why did Capricorn put every screw in one bag instead of putting the screws for each component together like everybody else does?For $699.00 I expect better attention to detail. Just venting.
Old 01-21-2012, 10:19 AM   #1331
The white eccentric roll centre inserts are made out of a Teflon based material.
This makes them smoother compared to the standard black pieces.
Can you tell me what you disliked about the manual, either here or by pm?. The manuals are improving every time, that's also why they decided to go with a digital version, so we would like to know what parts need improving?.
I will ask about the screws, and if it's possible to change it in the future.
Personally I like them to all be in one bag since I never follow a manual when building a car.
P1-RC.com
Old 01-21-2012, 01:05 PM   #1332
Some people whinge about everything! Find something real to complain about! You got to understand that you're alone with this trivial matter; no one else has complained about it on this thread or the the CO8 thread so far after so long, and you won't have much fun with this or any other car if this is enough to start whining about.
I was advised a long time ago to always start any new build by sorting the components, before doing anything regardless of how they are organised or the manual. Everybody else does not put "the screws for each component together". Most cars that I've built have had the screws in packs just like Capricorn, and it's quicker and easier for me to have all screws sorted to sizes. But the again I suppose some of us organise ourselves differently.
I've seen full size manuals that have better details (and also worse), but the Capricorn manuals are perfectly adequate; and covers the build with details perfectly, although any manual can be a bit daunting for an inexperienced person. But the pictures are the best I've come across. The small size Capricorn manual is a handy size to bring to meetings; but you won't find an exploded view in it, it would be probably have too small pictures of the components.
Kindest regards,
Lars.
Old 01-21-2012, 01:18 PM   #1333
Double post deleted.
Old 01-21-2012, 03:07 PM   #1334
Dear Lars Capricorn I'm sorry I insulted your product that you worked so hard at developing. You are wrong about being alone on my complaints I have heard and read complaints on these very issues.I did notice that you didn't think my observation of fit and finish was "whining " . Mr capricorn please try not to be so hypercritical about someone else's opinion if I open my wallet and purchase a product then i have purchased the right to point out in MY opinion some things that need a little attention.2 complaints on a overall outstanding kit is not bad.I have one final question where are these meetings you take your manual to so I can warn all my friends to stay away(hey kev) I wouldn't want them labeled as douche bags
Old 01-21-2012, 04:16 PM   #1335
I'm feel very insulted and I'm considering a dose of sleeping pills to end it all after your terrible criticism of the manual and packaging. My sincere and genuine apologies, but I simply cannot reveal which tracks we race at. I wouldn't like to be responsible for reduced attendance due to bringing a manual to the track, but I promise to keep it secret if I see one of your friends there. I'll also hide the manual so no-one will notice how pathetic I am bringing it to the race track. Could I please ask you not tell anyone that I bring it to race meetings though? I couldn't bear the embarrassment if it was discovered.
Thanks for your reply, I just love it when someone bites.
Kindest regards,
Douche Bag Lars.
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
