Capricorn LAB-C01
#1246
Well I ran the C02 conversion kit this weekend and if was very good. We had the 4th round of the Florida State Series and I was able to take the win convincingly by a couple of laps. I really the rear camber links being so easy to adjust. I also ran the blade bar, but did not even try to mount the wire bar. I will check into that with Capricorn to see what is coming if anything. Not sure if it is needed though. I had plenty of steering, thats for sure. I will put together a set-up over the next couple of days. Today I am busy getting back to work.
DJ Apolaro
DJ Apolaro
#1247
DJ Apolaro
DJ Apolaro
Kindest regards,
Lars.
#1249
The more flexible top deck seen in the pre-production photos is called "FFS" and it appears to be an option part:
#1250
since modifying my top deck to look like the FFS one my car has been so much better.
To me the C02 looks like it has been designed to make the front diff easier to remove and also to improve make the cars drivelin.
will be interesting to see if anyone has done some back to back testing with the two.
also the new camber and roll centre settings look really good but is the cars geometry changing also?
#1251
DJ Apolaro
#1252
Kindest regards,
Lars.
#1253
I do not want to clutter up this forum, but I posted a car for sale in the "for sale" forum. If interested check it out.
http://www.rctech.net/forum/r-c-item...l#post10026846
Thanks,
DJ Apolaro
Thanks,
DJ Apolaro
#1254
Finally finished...
Hey guys,
I thought id post pics of my finished C01... Not a racer like most but just love this car, the build and soon, the drive...
Also soon to get my C02 upgrade!
#1255
more pics..
Here is some more pics
#1256
LAb c01 upgrade
2.2mm lab c01 wire ARB With two CAP-16010 and two 5x8x2.5 bearing...
G
G
#1257
Got my Lab C02 kit but was quite disapionted as it had the normal front sway bar blade and not the new system.
The top deck is not the flex system but will modify the carbon.
need lots of steering so I wish the know if the new front sway bar system will help?
#1259
I always saw it advertised with the new sway bar so I took it for granted. I also just noticed that the spring are way softer than the red springs, how come?
#1260
I do know a lot of drivers still like the blade style arb so maybe that's why it's included.
The new wire stabi is very nice though, it will be super easy to change it without having to reset the tweak.
I advice to test the radio tray as provided in the kit, if you feel like you will need more steering or your track is very bumpy you can try cutting the radio tray.
I will build mine as standard and first thing I will test is the flex radio tray.
The springs provided are between the white and red springs in terms of stiffness. The original black springs might have been a bit too stiff for most tracks.
