Old 08-22-2011, 07:47 AM   #1096
DS Motorsport's Avatar
Originally Posted by mc_chofo View Post
hi to everybody, i just got a lab c01 but haven't received it yet, so i have a couple of questions about the car, just to get ready before it gets to my hands.
do you know if i can use the the nt1 rear antiroll bars on the c01?
what battery are you using with the car? lipo or life?
have you tried the dark red shoe? how does it works?
how about using the white shock springs for a low traction track? or can i use the nt1 ones with the lab? well do they work as they were the same?
and does any of you have tried the new clutch bell? can remember de material name
and if you have any advice for the car it will be appreciate it.
by the way i got the euro version
-No you can't, the lab uses a different mounting system for the arb.
-I like using a lipo without a regulator, I do have a steering servo and a receiver which can cope with the additional voltage. Most Life batteries are too big, which doesn't allow you to lower the tank.
-The dark shoe works very well, it does need a powerful engine to work at it's best. With a low power engine the clutch has too much grip. I use a gap of 0,45 and 0,50mm of spring pre tension.
-You can use the Xray spring on the lab, the dark blue Xray springs work very well on a low traction/bumpy track.
-The new aluminum bell together with the black shoe is very good. I used it at the euro's last week and it defiantly improved the car's acceleration.
Start out with a gap of 0,40mm and 0,40mm of spring pre tension.
On the following link you can find a manual on how to build the shocks and clutch:
http://dsmotorsport.nl/DS_motorsport...Downloads.html
I also posted a build report about the Lab in this thread but you have to search for it, I can't remember the post number.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 08-22-2011, 08:11 AM   #1097
thank you very much DS, have you tried the ergal bell with the red shoe? or you went straight to the black one?
mc_chofo is offline   Reply With Quote
Old 08-22-2011, 08:12 AM   #1098
also how about the swapping the side belts from the nt1 with the capricorn ones? i'm a little confused about this.
Old 08-22-2011, 08:50 AM   #1099
It's advised to use the black shoe with the aluminum bell, this gives the best performance and longest life for both shoe and bell.
You can use the front and rear belts from the NT1 on the Lab, the side belt doesn't fit, the Xray one is too long.
P1-RC.com
Old 08-23-2011, 04:09 PM   #1100
dj apolaro's Avatar
Hey guys,
Some racers have asked for my set-up at the Chaplin track. Here you go!
DJ
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 09-01-2011, 11:26 AM   #1101
Default New to Capricorn
Hello I recently got a capricorn and while assembling it I noticed that the front bulkhead assembly came with two left hand side upper suspension mounts. I have looked all over for the right part as well as a contact to someone who can get me the correct part and I have had no luck yet. Who can help me with this problem, I want to race this car at my last race in a couple of weeks and I really need to get this part for the car.
Thanks,
mrod is offline   Reply With Quote
Old 09-01-2011, 11:39 AM   #1102
dj apolaro's Avatar
I just sent you a PM. Hope it helps.
DJ
Old 09-01-2011, 02:50 PM   #1103
Chickentrader's Avatar
Thanks,
Capricorn Australia at http://www.radicalrchobbies.com.au/ keeps all parts in stock.
Or you could go to:
http://www.capricornrc.com/capricorn..._search=Search , http://www.capricornrc.com/capricorn..._search=Search, or Email: [email protected]. if you're in Europe.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 09-03-2011, 03:53 PM   #1104
pinoy69racer's Avatar
Trader Rating: 180 (99%+)
ty guys
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 09-06-2011, 09:40 PM   #1105
Trader Rating: 13 (93%+)
Default top deck stiffeners
Hi guys has anyone tried these top deck stiffeners as used by giorgio felici at the recent euros??
http://events.redrc.net/wp-content/g...efelicicap.jpg
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 09-07-2011, 05:01 PM   #1106
I actually tried something different at the EC. Me and a another driver felt the car was too stiff for the track because of the bumps and off camber corners. This caused the front to understeer quite a lot while turning in.
Because of this I decided to cut the radio tray and mount a cross brace to keep the front bulkhead from collapsing.
This provided a lot of turn in and the washing out of the front end over the bumps was cured.
You can adjust the amount of flex by changing the amount of cross braces and screws holding the radio tray in place.
I also used a turnbuckle instead of the carbon or plastic brace between the two speed bulkhead and radio tray support:
Also working on some new parts:
Just came up with a nice system to mount them on the outside of the rim as well, probably will have that made next week.
P1-RC.com
Old 09-07-2011, 05:09 PM   #1107
Looks good
a driver at our local track made the same top deck changes to his rx8 and it made a big difference to turn in. i have a spare top deck so i might modify one also.
i like the mrx5 inspired carbon discs..
Old 09-07-2011, 05:44 PM   #1108
Default Interesting.
Interesting; but I doubt that we'll try it, our car is just awesome as it is. Are the nylon ball ends on the steering linkages a Capricorn part?
Kindest regards,
Lars.
Old 09-10-2011, 04:46 PM   #1109
Kindest regards,
Lars.
If you have some high speed corners at your track (2nd gear) you should defiantly try them at the front. I had some time today to really test various aero parts and the carbon discs really made a difference. It adds steering to the front and because of this I didn't have to turn the wheel as much, which helps for the corner speed.
The white plastic pieces are a teflon based plastic, these ball ends are super smooth.
They are new parts from Capricorn and are already available, they have the same part # as the normal plastics but have a W added to the number.
Some new info:
Capricorn Spring table:
www.dsmotorsport.nl/Manuals/Springs%20table.pdf
Capricorn Clutch setup sheet:
www.dsmotorsport.nl/Manuals/blank%20set%20up%20sheet.pdf
P1-RC.com
Old 09-11-2011, 02:54 PM   #1110
Some new info:
Many thanks for all that. Your are a great source of support and information for Capricorn drivers.
Kindest regards,
Lars.
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
