Old 06-23-2011, 05:59 PM   #1051
Trader Rating: 13 (93%+)
There is no W.C kit, its the European Championship kit which has been out for quite some time now.
the floating radio plate is for the 1:8 scale. The lab c 01 does not need a floating radio plate. if you need more flex you can remove the screw that holds the top deck to the front belt tensioner, or if you need flex in the rear you can remove thwe screw that screw the 2 speed support posts to the rear bulkhead.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 06-28-2011, 05:17 AM   #1052
Default duralium engine mount
hi guys i have a capricorn duralium engine mount to install in my car, what benefit other than placing weight in the chassis is there? does adding weight to this part of the car affect steering?
at the moment to bring the car up to weight i have 30gs screwed to the chassis on the exhaust side
Old 06-28-2011, 11:08 AM   #1053
djiewie's Avatar
this is basically an improved nt1 so MArtin Hudy says that this will get you more steering on the xray site. Try to balance the car left to right and get the weight in the middle of the car.
djiewie is offline   Reply With Quote
Old 06-28-2011, 03:36 PM   #1054
DS Motorsport's Avatar
It moves the engine 0.5mm to the left for better balancing.
You add weight to the CoG of the car which helps improving the amount of steering the car has but also making it react faster, makes it more agile.
The material used for the mount isn't duraluminum but a material which has a lot higher density. This improves the engine cooling quite a bit, you will notice the chassis getting a bit hotter since the heat transfer from crankcase till chassis is improved.
You probably won't need the 30 grams on the exhaust side anymore.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 06-28-2011, 03:37 PM   #1055
Yes, and the NT1 a copy of the Mugen MTX-4.....
P1-RC.com
Old 06-28-2011, 05:24 PM   #1056
Chickentrader's Avatar
The NT1 is really only a cloned MTX4 with improvements; and I've heard some calling them "MTX4 1/2", but just because some of the parts fit both the LAB CO1 and NT1, and they share design features but not quite "basically an improved NT1". But handling tips from Hudy should work on any 1/10th scale on-road gas car.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 06-28-2011, 10:58 PM   #1057
Thanks for the update
yeh ill be installing it to my car and removing the other weights.
any new hop ups that your aware of to be released?
Old 07-01-2011, 08:30 AM   #1058
dj apolaro's Avatar
Default Set-up
Hey guys,
I went to the Chaplin track last weekend. They had there Regional Race and I attended to help out racers and continue to test for the Nationals later this year. You will not find my results, as I am not a part of their Region, but my car was pretty good and this is the set-up I used. I took the fastest lap and fastest in the qualifiers. This is a high bite and bumpy track.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 07-01-2011, 07:07 PM   #1059
dbl post
Anthony Andrews
laptraffic is offline   Reply With Quote
Old 07-04-2011, 10:27 PM   #1060
Hello,
Can any one help with gearing for a big track?
Thank you
dex410usa is offline   Reply With Quote
Old 07-04-2011, 10:57 PM   #1061
Originally Posted by dex410usa View Post
Hello,
Thank you
Use standard gearing as in the file attachment, or you can gear 1st lower for a big track with some hairpins or sharp corners.
Kindest regards,
Lars.
Old 07-05-2011, 06:49 AM   #1062
dj apolaro's Avatar
Hello,
Thank you
15/20 52/47
DJ Apolaro
Old 07-05-2011, 02:16 PM   #1063
Thank you
Old 07-05-2011, 03:09 PM   #1064
Thank you
For a point of interest; which track are you racing at? I would like to have a look at it with Google Earth.
Kindest regards,
Lars.
Old 07-05-2011, 10:28 PM   #1065
I am going to this one at the end of the month http://www.timezoneracing.com/timezone.php
and going to a parking lot track that is huge!!
Kindest regards,
Lars.
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
