Old 05-20-2011, 03:35 PM   #1021
Chickentrader's Avatar
Originally Posted by blackyblackman View Post
Hi!
Did someone use these shims ('Belleville' springs) in a Capricorn LAB-C01 WCE clutch??
http://www.rctek.com/cars/pb/dart/mo...de_clutch.html
If yes, how much shims did i have to use??
10 or 12?
And how much is the pre-load?
I have testet it with 12 shims and a preload of 0,3-0,4, but it works not really good!!
Any suggestion??
Regards,
Michael
Is there really a need to use disc springs in Capricorn clutches. Aren't disc springs heavier than coil springs? Capricorn clutches are intentionally made as light as possible, and that's one reason why they are better. We already have the best clutches in the RC world, and there are a multitude of coil springs from all manufacturers to choose from. Most; if not all the drivers in the Worlds 2010 final used Capricorn clutches, and I doubt that there were any disc springs in their clutches. But it would be interesting to hear from someone that can enlighten me further on this issue?
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 05-20-2011, 07:04 PM   #1022
DS Motorsport's Avatar
Kindest regards,
Lars.
I have a set to try, if I find the time I might try it tomorrow.
I already tested it in a Nova Basic N12T1 engine and the results were very good.
You can also alter the stiffness and character of the spring by changing the orientation of the belleville rings.
Like this is the softest: ><><><><
Like this it's harder: >>><<<><
Smaller changes can be made by altering the preload.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-22-2011, 07:04 PM   #1023
Joehwee's Avatar
Originally Posted by Joehwee View Post
Hi guys
Can someone tell me what is the difference between the yellow, red and the older green clutch shoes?
TIA
Any update?
HB Racing - OS Engine - VP Powermaster - Nosram - Sanwa - Schumacher Racing - HPI Racing - CapricornRC - Dualsky - Savox - AKA - Juc Racing - Team Orion - SMJ - MM Spec - Muchmore Racing
Joehwee is offline   Reply With Quote
Old 05-23-2011, 04:13 PM   #1024
Any update?
The yellow and green shoes are older versions, currently I would recommend the red shoe anytime as it gives the best performance.
P1-RC.com
Old 05-23-2011, 09:39 PM   #1025
blackyblackman's Avatar
Hi!
Any Update??
Have you test it last weekend??
I had no time last weekend to practice, perhaps i will test it today..!
Black
www.BLACKRACING.de
XRAY NT1 2013 - XRAY T3 '10 - XRAY X12 LINK - XRAY M18 PRO
blackyblackman is offline   Reply With Quote
Old 05-24-2011, 07:42 PM   #1026
Trader Rating: 13 (93%+)
Congrats on your win DJ at the recent Kosmic Gp
can you please post your setup pleasE?
thanks!
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 05-25-2011, 03:03 PM   #1027
dj apolaro's Avatar
thanks!
Here you go. The traction was high just so you know. I also used the stock springs and tested the reds, but the stock ones were better. Even thought the track was bumpy the stock springs made the car produce faster lap time. I just had to watch my driving line a little closer and make the track as short as possible.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-28-2011, 05:08 AM   #1028
Which Ackerman plate is the more Ackerman ?
10 11 or 12?
Old 05-30-2011, 01:40 AM   #1029
TMF
+ YouTube Video
TMF is offline   Reply With Quote
Old 05-30-2011, 06:21 AM   #1030
GREGORY!'s Avatar
Originally Posted by TMF View Post
+ YouTube Video
is it a video from Auto Paris Show 2011?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 05-30-2011, 07:09 AM   #1031
TMF
Nooo it's my 1st home made video
Old 05-30-2011, 09:51 PM   #1032
SlowPushin's Avatar
i had a 35 min main and 15 minutes in minutes in my brakes started to fade. Is there a issue with the brake pads , or maby my servo started to fade?
IT's Not THe CAR,IT's THe NUT on the GRIP
S e r p e n t [7 4 7] [4 1 1]
SWEEP TIRES
ENNETI TIRES
SlowPushin is offline   Reply With Quote
Old 06-01-2011, 11:43 AM   #1033
If pads and disc are brand new, use very fine ( almost dead ) abrasive paper as DJ says.
Also check 2 screws holding pads. Those screws get loose. I used some threadlock to solve the problem.
1nsane is offline   Reply With Quote
Old 06-01-2011, 12:03 PM   #1034
The red Capricorn brake pads don't fade in our experience. We often race on narrow track with tight corners, where fading brakes is common, and we have never had that problem. Try changing your servo. The bolts need threadlock to stay steady when the thread in the bulkhead gets worn in, and the bolts are starting to turn too easy.
Kindest regards,
Lars.
Old 06-21-2011, 11:07 AM   #1035
Default Cap Set-up Help
After reading every thread on the hottest touring cars I decided to purchase this car. Please dont flame my for this, but there are not onroad track were im from so we drag race the cars. Its not just parking lot racing we actually use a real timimg (Pro-Tree 400) system for ET and MPH. The distance is 132ft. start to finish. All of my competition runs MTX 3 with .21 motors on them. The surface is untreated so foam tires do not work bc of all the power we are putting down. We use rubber tires.
I will not put a .21 motor on this car unless i absolutely have to. I figured with the light weight components on this car I can get away with running a drag modd TZ .18.
Ok>>That's the snap shot, heres what I need for my application:
What gearing and pulleys should I use? (We tend to gear more to the top side bc of the power of these motors)
Overall total set-up..i.e..Rear tow, camber, caster, shock position,
Whats the best body to run? I ordered the ISF body, but was thinking about the toyota GT one.
Ride height?
Any feedback would be greatly appreciated. Thanks to Sam, the kit should arrive today. I will start building tonight.
Thanks,
kpjr7321 is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
