Old 04-20-2011, 07:43 PM   #961
Trader Rating: 13 (93%+)
Default off capricorn topic
some more pics of this michael t mods..
the first is a picco sleeve mod, the second he was trying to acheive the darth vader look on the sleeve.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 04-20-2011, 08:37 PM   #962
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
Michael_T is online now   Reply With Quote
Old 04-21-2011, 07:36 PM   #963
i don't know anything about cutting sleeves, nor what those cuts would do, but it looks very impressive!
TomB is offline   Reply With Quote
Old 04-22-2011, 04:49 AM   #964
Capricorn browsing the site I saw it: PIASTRINA (Plate) DOWN STOP ALLUMINIO - CAP 17060
I wonder where she goes to the chassis?
Thanks,
Potenci is offline   Reply With Quote
Old 04-22-2011, 10:08 AM   #965
Team Kamikaze's Avatar
Thanks,
It replaces the 2 down stop tabs on the front lower A Arms, when using the 17060 you will need to cut off the existing tab (for the down stops) from the lower arm
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-22-2011, 02:53 PM   #966
DS Motorsport's Avatar
Thanks,
You can see it mounted to the car on the picture below:
As kamikaze mentioned you have to cut off the existing downstop tab on the lower wishbones.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-23-2011, 11:07 PM   #967
blackyblackman's Avatar
Default DOWN STOP ALLUMINIO
Hi!
I have mounted them this weekend and test it on track.
They work perfect!!
Regards,
Michael
WWW.BLACKRACING.DE CAPRICORNRC.DE
CAPRICORN LAB-C01 - XRAY NT1 2010 - XRAY T3 '10
blackyblackman is offline   Reply With Quote
Old 04-24-2011, 02:48 PM   #968
I made a diy receiver protection ( used nt1 box with some modification, gonna post pictures ). It weights 18 grams and it is too much weight for protection. I hate the idea of unprotected receiver. Anyone using receiver next to pipe or somewhere else?
I almost finished building the kit. I bought 2 kits, 1 spare and 1 one for racing. One kit has 3 defective parts, other is perfect.
Rear joint cups. Cups are too small ( shaft does not move freely ) and 1 one of the small parts ( the one enters drive shaft) is too thick.
Brake level 16029, hole diameter is too small ( Easy fix with dremel )
I have a suspension arm reamer and it is a must have tool for Lab.
My throttle servo is Futaba BLS451. I will change it with a Savx low profile and lower it by 4-5mm with shims ( DS's idea ). More than 15 grams of weight savings.
I will replace all the screws holding radio plate with Ti ones to lower CG.
I have the heavy engine mount cap-16005b. It weights 50.3 grams vs 15 grams standard. It is advertised %300 heavier vs kit mount but it is more. I am curious about engine temps.
The kit is great. I have been spending lots of time with building and I know it will be worth it. Even I am an inpatient guy, I am happy with the slow building progress. The car is perfect and it deserves a perfect building.
Season opening race this weekend, can't wait
1nsane is offline   Reply With Quote
Old 04-24-2011, 04:56 PM   #969
18 grams is too much weight for a receiver box, but you use a 300% heavier engine mount???
I think nobody will do this!
Because you have to route the cables through the whole car!!
From the servos to the other side to the pipe and back to the battery...!
No good idea..!
And: I dont know where you are from...
But here in Germany we have a minimum weight of 1700 grs. for official races!
And the Lab is absolutely underweight out of the box!!
I have problems to find enough space to put nearly 160 grs. into the car!
So you dont need Ti screws, lighter servos or other stuff to reduce the weight!
(If you race official races!!!)
Regards,
Michael
Old 04-24-2011, 09:50 PM   #970
Chickentrader's Avatar
Default Capricorns NSW State Titles
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 04-25-2011, 12:53 AM   #971
No good idea..!
Regards,
Michael
I am from Turkey and 1700gr is limit here too.
18 gram to right side edge will mess up weight distribution. Imo heavy engine mount is a must part because it lowers CG quite alot just like brass battery plate and it is more dense so it will flex less.
I actually need lightweight servos to use the heavy engine mount. I will not use Ti screws everywhere. Only at upper chassis to lower CG.
I plan to use 40-50 grams of tungsten weight for balancing. Using %10 weight to make a car legal is not easy. Where do you put all these weight without changing 50-50 right left balance?
When I finish build in a few days, I will post weight scale and cars pictures.
Thank you
Old 04-25-2011, 12:53 AM   #972
Default FRENCH NATIONALS LIGUE 6 METZ
1.) CLEMENT Adrien (???/???)
2.) HEYER Julien (Sheperd Velox V10/???)
3.) SCHWARTZ Michael (Capricorn LAB-C01/JP FX 03T tuned by MH/Novarossi 2652)
Old 04-25-2011, 01:28 AM   #973
Hi!
Weight of the carbon fibre plate with a LiFe-Battery is 75grs.
(i use that for friendly races!)
Weight of the brass battery plate with extra lead plates and LiFe-Battery is 209 grs!!
(i use that for official races!)
Look here:
And why do you make the install of your receiver box so complicated??
I use a very simple solution and you have nothing to cut or to modify at the chassis or at the Xray receiver box!! (ok... two extra holes for the screws...!! )
Look here:
Regards,
Michael
Old 04-25-2011, 06:25 AM   #974
kickass's Avatar
Hi!
Look here:
Regards,
Michael
Your talking about two of my mates of Middle Eastern Appearance who get together one night and "Shazam" - MacGiver is reborn again.
One reason which may explain this is the fact that these two Gentlemen have changed more car brands between them than I have undies in the last 12 months. Oh Johnny woohnt ya come back hohoome- Xgay misses you.
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 04-25-2011, 07:13 AM   #975
Hi!
Look here:
Look here:
Regards,
Michael
Hi,
You receiver solution is not safe because it has only 3mm contact patch to radio plate and only 4 screws holding it. Its back is empty.
Gonna post pictures tonight.
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
