Old 02-25-2011, 02:45 AM   #901
Chickentrader's Avatar
Originally Posted by DS Motorsport View Post
Pretty much completed my car for the 2011 season, still need to do some clean wiring but haven't received the shrink wrap I need.
The car turned out pretty light for this year.
This is with all Ti screws, one low profile servo, Magnesium bulkheads and lightweight 2-speed axle. The rest is as standard. I could make it even lighter by using a low profile servo on steering as well and removing the exhaust gas cooler. Plus the Capricorn exhaust is one of the heavier ones.
Are you allowed a car that light in Holland? Our minimum weight is 1725 gr., and I thought that this was consistent with IFMAR.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 02-25-2011, 07:20 AM   #902
DS Motorsport's Avatar
Kindest regards,
Lars.
We're running under efra ruling so it's needs to be 1700 grams.
So I still have some weight to add, the heavy motormount helps but I would still need to add some Tungsten weights.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 02-28-2011, 02:03 AM   #903
I received my lab just over a week ago and am very satisfied with the quality of parts and the build itself. The only thing I don't like about this car is the way the receiver is mounted. personally I would prefer a case around it, to have a little bit more protection from side impacts. Does anyone know it is possible to mount an NT1 or a 733 receiver box in the lab?
ma_RC_el is offline   Reply With Quote
Old 02-28-2011, 12:32 PM   #904
Some of my mates have fitted a NT1 receiver box to their Capricorn. The receiver box needs only a slight modification to fit apparently. It shouldn't be hard to figure out how; but I could find out if anyone wants to know the details. Personally; I'm happy to have it exposed, it's easier to check that the plugs are right that way.
Kindest regards,
Lars.
Old 02-28-2011, 04:49 PM   #905
TMF
Look this pics:
https://picasaweb.google.com/1169231...NnsxN6OhvjCBg#
TMF is offline   Reply With Quote
Old 03-01-2011, 05:31 PM   #906
Completely finished the wiring today.
Decided to get rid off the regulator since I know have a Lipo ready steering servo and receiver (Koprope RSX and Sanwa 451R) and I'm guessing the Futaba throttle servo will be able to cope with the additional voltage.
Might put the PT in a different place since I don't like it sitting on top of the radiotray.
P1-RC.com
Old 03-01-2011, 08:03 PM   #907
Hi DS,
What is the covering that you use on all your wiring ????
thanks,
Mike Schroder is offline   Reply With Quote
Old 03-01-2011, 08:08 PM   #908
Originally Posted by Mike Schroder View Post
Hi DS,
thanks,
heat shrink maybe.
yappy is offline   Reply With Quote
Old 03-01-2011, 08:10 PM   #909
Originally Posted by yappy View Post
heat shrink maybe.
yeah thats what i thought but heat shrink isnt as flexable as what ds is using or as shinny...
Old 03-01-2011, 10:00 PM   #910
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Those are a specially designed heat shrink which is lightweight flexible and shiny...
DS, lemme know where to get some cuz that steering servo wire looks pretty awful in my car!!
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 03-02-2011, 04:37 AM   #911
It's a fairly exotic neoprene based mil spec heatshrink. This is the stuff we use in 1:1 motorsports.
I don't know the brand of the one I used but after some googling I found this one:
http://www.buyheatshrink.com/heatshr...eat-shrink.htm
For smaller amounts you might want to contact them.
For normal servo wires you will need the 3/16 size, I also use different wiring so I can get away with using 1/8 size.
P1-RC.com
Old 03-03-2011, 10:55 AM   #912
Nipple's Avatar
Anybody can kindly advise what thickness/diameter of the front sway bar is equivalent to the original blade type at 0 degree?
And is there any difference in performance between the WC edition red 2 speed shoes and the original black colour ones?
Many thanks in advance.
Nipple is offline   Reply With Quote
Old 03-03-2011, 11:17 AM   #913
The final version of the Website is under development. For the time being you can access the website with the contact info. We will be more than happy to answer your requests.
[email protected]
http://www.capricornrc.us/
www.desotoracing.com
[email protected]
Desoto Racing is offline   Reply With Quote
Old 03-03-2011, 11:24 AM   #914
The 2.2mm wire gives a pretty equal feeling compared to the 0 degree blade.
The recently released black 2 speed shoes are made of a different material and should provide more consistent shifting.
The kit I have already came with the red WC shoes.
P1-RC.com
Old 03-03-2011, 12:02 PM   #915
Nipple's Avatar
Thanks for the information.
So the black 2 speed shoes that comes with my kit are actually the newer ones.
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
