Capricorn LAB-C01
#766
Congratulations to Capricorn drivers Stephen and Peter Jovanovic; 1st & 2nd in the Victorian IC Titles.
Kindest regards,
Lars.
Kindest regards,
Lars.
#767
Congrastulations !
#768
Soft option
Hey Guy's,
Just wondering what arms and hubs the majority of people are using the standard ones in the kit or the soft optional ones ????
Cheers,
Michael
Cheers,
Michael
#770
The soft plastics will give the car a bit more a vague feeling, more like the NT1.
So I would only run them when the track is really bumpy or really low traction like an untreated parking lot.
Personally I rather keep the hard suspension pieces and make the car work by tuning in the spring/damper settings since this will give you a faster overall car. However using the soft plastic suspension pieces is the quickest option if the car isn't handling properly.
#771
I would also say this depends on how much you hit. The softer plastic gives a little more and takes hits better. I think the US kits come with the soft stuff and the rest of the World comes with the hard. I think!!
You know, we have big boards over here.
Hope this helps,
DJ Apolaro
Hope this helps,
DJ Apolaro
#772
Hope this helps,
DJ Apolaro
Hope this helps,
DJ Apolaro
Would it be an option to keep the hard wishbones and just run the soft uprights and steering knuckles on a US track?.
Most of the time the knuckle or upright takes the hit.
With this combination you have the best of both worlds I think, might be interesting to test.
#773
I would advice running the hard plastics as much as possible as these are partly responsible for giving the car it's great and razor sharp handling.
Hope this helps,
DJ Apolaro
Hope this helps,
DJ Apolaro
Have you tried the hard arms and hubs at all ?
thanks for the replies
#774
I am using the hard hubs and knuckles with the soft arms. I have been running this as that is how the car came. I am going to put on all the hard plastics just to see the next time I run. I rather be faster and break if I hit, but thats just me.
I just have not had time for anything. That is the main reason for running the car stock. That and it has been working good so I have not felt the need to change much.
DJ
DJ
#775
DJ
DJ
#776
Parking Lot Setup
Hey Guys,
Does anyone have a setup for a low traction bumpy Parking Lot Track? Im not having any luck with the setups I have found.
Also does anyone else get Goat sounds when your car drives past?
-Chris
-Chris
#777
I haven't driven the car like this myself but it should give you a car with good traction with a bias towards understeer.
If you setup the car like this and try it I can help you further if it's still not handling like it should.
I don't get any goat sounds, just a sonic boom once or twice when I'm ripping up the track.
#779
