Old 12-04-2010, 06:38 PM   #676
Very nice pictures TMF, cool to see the weight of some parts...!!!
Can you tell me the weight off the car, i mean the car like its from the kit,
so, just the car, no wheels, body, engine, battery, servo`s etc....
Just the kit weight..!
(maybe he knows ...DS..?)
Regards,
Roy
rbakker is offline   Reply With Quote
Old 12-04-2010, 06:52 PM   #677
Default assembly help
on step 1.0 #7 the white plastic is not flat on the new kit it has a lip now does the wider part go face down into the shock body or does the wider part face up? im finding it hard to get #8 in after the this?
Also I don't see a shim for step 7.0 #5 I checked many time but dont see this 6x10x0,5
younghovaa is offline   Reply With Quote
Old 12-04-2010, 07:01 PM   #678
DS Motorsport's Avatar
The wider part of the guide goes towards the bottom of the shock, towards the clip which holds everything in place.
In order to get part #8, the clip, in it's groove you need to put a little pressure on part #7 so you can compress the O-ring. The O-ring needs to be compressed a little in order to have a good seal.
Part #5 in step 7 is a plastic spacer which is located on one of the part tree's. I can't remember which tree it is, it has a dark grey color.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 12-04-2010, 07:14 PM   #679
Thanks sooo much thought is was metel @ first.. this is awsome
Old 12-04-2010, 07:23 PM   #680
TMF
rbakker, I can't tell you cause I'm building the kit.
Oooooh yes !!! that plastic spacer !!! I didn't find the shim, so I put an old brass shim standar glow plug
TMF is offline   Reply With Quote
Old 12-04-2010, 07:44 PM   #681
Default offset
DS where you placing your offset shims for front and rear? do you do one inside one outside? I have total 8 offset shims.. book say one inside but i read someone had one inside one outside on new kit?
Old 12-05-2010, 06:21 AM   #682
When I was building my kit I was looking for a metal shim as well.
Standard setup has one shim on the outside and one on the inside.
I started with both shims on the inside all around, so the least amount of offset, because I like this setting. Makes the car react better in the fast direction changes.
P1-RC.com
Old 12-05-2010, 04:16 PM   #683
TMF
I'm uploading more and more pics.
The carb linkage is provisional, as I'm waiting for a Futaba BLS551 low profile servo.
Old 12-06-2010, 10:33 AM   #684
dj apolaro's Avatar
Hey guys. Just got back from racing again this weekend the car was great. I put in the diff and liked the car just as much as with the spool. The traction was very high and I had to use heavier diff oils for my liking. I ran 300 in the front and 100 in the rear. This was mainly for the high bite. I think the diff and spool can both be made to go really fast, but the diff gets a little better turn in. I like the stability of this car. The rear end stays planted and accelerates great. Am going to work on the car to get a little more rear end rotation for corner speed. I think I will make the rear link a little shorter next time and with the angles a little more.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 12-06-2010, 10:55 AM   #685
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default main
what happened in the main? did not get a chance to ask you
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 12-06-2010, 04:28 PM   #686
DJ Apolaro
Yes, the rear end grip this car has is pretty incredible.
Laying in the rear shocks worked very well for me in order to get some more rear end rotation.
I also went with stiffer rear springs, stiffer rear ARB and reduced the toe in to 1 degree.
For next year I'm going to try softer front tires, normally I run a split of 2-3s shore, going to test with 5-6 shore.
P1-RC.com
Old 12-06-2010, 04:35 PM   #687
DJ Apolaro
hey DJ what track did you race @? Also what did the car do to make you know to go to a heavier diff?
Old 12-06-2010, 08:49 PM   #688
Capricorn Lab C01 wins second FSS in a row
Congrats to Eduardo Cabal for winning the round #4 of the Florida State Series.
Second victory in a row for the Lab C01
www.desotoracing.com
[email protected]
Desoto Racing is offline   Reply With Quote
Old 12-06-2010, 10:00 PM   #689
dj apolaro's Avatar
You know racing. I came in for a pit stop and when I left the rear diff went out. Sucks going from leading a race to a DNF. hehehe But the car was good, so next time will better.
DJ Apolaro
Old 12-06-2010, 10:03 PM   #690
dj apolaro's Avatar
It was a new track here in Florida. It is in Arcadia. I wanted the car to have more on power steering and dive in harder for the turns. I know a heavier rear diff would help. I also wanted the car to track better when I got on power and a heavier diff in the front helps this. I almost wanted to run a spool, as thats what my driving style like, but I am playing with the diff, as that seems to be what most people use and I want to help racers out with set-up ideas.
DJ Apolaro
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
