Old 11-18-2010, 01:14 AM   #601
el salvador's Avatar
Thumbs up
The NT1 and LAB-C01 Brake Pads interchange.
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 11-18-2010, 01:31 AM   #602
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
sick, now i just have to find where to buy some in the states
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 11-18-2010, 03:40 AM   #603
DS Motorsport's Avatar
Originally Posted by Rawz View Post
Hey guys, about the brake pads, which side goes to the disc, the rougher ones, I am guessing, right? Glue the softer side to the metal pads?
Rough side to the metal plates, smooth side to the disc.
Originally Posted by rx7ttlm View Post
I am not asking DJ, he is fast with a matchbox car lol.
how are the brakes? and if you still have an NT1 could you tell me if the brake pads would cross over too?
Brakes are really good, strong but still controllable. Didn't experience any fading during the finals.
Capricorn sells the same set for the NT1, so they are perfectly interchangeable.
Since there is a new US distributer it shouldn't be a problem to order these parts, maybe contact Desoto racing on who is your nearest reseller.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-18-2010, 05:11 AM   #604
dj apolaro's Avatar
Hey guys,
Thanks for all the comments.
Just a tip for you guys that I found. When I first built the kit my brakes did not work very well. When I took them apart I noticed that the pads were no contacting the disk completely. I would recommend that when you build the brakes make sure to sand them flat with a fine sandpaper and also to sand the disk. Then clean the disk with brake cleaner. Once I did this the brakes were great. Just an idea!
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 11-18-2010, 05:19 AM   #605
dj apolaro's Avatar
Also I was at the shop yesterday and heard Paolo saying they were getting the first shipment from Capricorn today. I am sure they need a day or so get stuff in the system, so expect parts and kits to be available very shortly. Even all the hop ups for the other brands also.
Also I am waiting for a blank set-up sheet, editable version, to be able to post my set-up. When I get it I will post mine from this past weekend. Also I will be running the car in 3 weeks at a new track and will have more info to give. Maybe my first set up is not going to be the best, since it was my first race. Will have to see.
DJ Apolaro
Old 11-18-2010, 05:52 AM   #606
DJ Apolaro
I'm also waiting on an editable setup sheet, in the meantime I made one myself.
Maybe it's useable for you in the meantime:
http://www.rctech.net/forum/8019243-post474.html
P1-RC.com
Old 11-18-2010, 06:16 AM   #607
dj apolaro's Avatar
Here is an attempt at posting my first set-up. Let me know if there are any questions. Ia m going to work more with the diff at the next race, since that seems to be what the majority is using and I want to be able to help as much as possible. I prefer a solid, but I am sure the diff will be fast.
DJ Apolaro
Old 11-18-2010, 02:57 PM   #608
musti72's Avatar
Hi DJ,
Congrats on your new sponsor! Im sure Capricorn made the right choice to choose you for the team. Just wondering if Paolo Morganti will continue or not with serpent.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 11-18-2010, 03:27 PM   #609
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Paolo is staying with Serpent.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 11-18-2010, 03:50 PM   #610
dj apolaro's Avatar
Yeah, Paolo and the others are staying with the Serpent line..
DJ Apolaro
Old 11-18-2010, 05:50 PM   #611
rx7ttlm's Avatar
DJ Apolaro
Hey, is that serpent red spring the new serpent spring( circa 2008 silver spring)? Why so much rear camber? Wouldn't that take away a lot of rear grip in both forward bite and cornering grip?
Old 11-19-2010, 05:34 AM   #612
dj apolaro's Avatar
Yes, they are the new serpent reds.
The camber helped me get side bite at the apex of the turn for 2 troubled turns on the track. With less camber the car would just break loose and wash out in those 2 areas. I know racers have a theory about the camber and if too much you loose grip, but I have not had that experience. Once the tires wear in you regain that contact patch so it is fine. At the beginning you will loose grip, but once the tires come in its fine. That theory may be better when it is rubber tires or on real cars, but with foam I think it is not. but I am more of a piratical application person and not much of an engineer. hehehehe
DJ Apolaro
Old 11-19-2010, 07:21 AM   #613
Pattojnr's Avatar
Trader Rating: 19 (100%+)
DJ Apolaro
hahaha, yes i am the same, just some things are too hard to explain, but it just works. i know the theory, but it just doesnt come out right. lol
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-19-2010, 10:06 AM   #614
rx7ttlm's Avatar
DJ Apolaro
k, I am an engineering student so that explains it lol. . with radial tires they seem to love a lot of camber but from the testing I have done foam seems to act more like a bias ply. But I can say I have slowly gotten more ballsy on my setups (current one has about 4 on my base setup) But I think that was the first time I had seen 5.5 on a nitro car anywhere.
Old 11-19-2010, 11:40 AM   #615
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
Never seen a Toso setup then have ya? lol
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
