Old 09-29-2010, 09:06 AM   #466
KMW
KMW's Avatar
Originally Posted by DS Motorsport View Post
Will post my setup asap, trying to find a way to edit the setup sheet.
Sounds great DS, congrats! I couldn't find an editable version of the setup sheet either so I created my own, maybe it will be useful to you:
http://www.nil.org/download/Capricorn-Setup-v1.0.pdf
KMW is offline   Reply With Quote
Old 09-29-2010, 12:17 PM   #467
td-civ's Avatar
Trader Rating: 18 (95%+)
hey guys i just got this car and im looking for some input on what i should buy for it or change
i use to run a nt1 and every one told me its base off of that car
any input will help
thanks tuan
td-civ is offline   Reply With Quote
Old 09-29-2010, 01:00 PM   #468
DS Motorsport's Avatar
Ok, great.
However if I save the file only the text stays, the checked boxes like shock position disappears after I've saved it. I use Preview under Mac OSX, normally this works brilliantly.
any input will help
thanks tuan
Hi Tuan,
First of all, great choice you made, you aren't going to regret it.
With what you should buy for it are you talking about spares, or optionals?.
Basically there are only two optionals available: the kevlar pulley set and the front wire type anti roll bar. The kevlar pulleys are a good thing to buy once the original pulleys have worn out, the kevlar pulleys really do make a difference, it makes for an even smoother drivetrain and they don't attract any dirt.
I really like the front wire type ARB, no more endless tweaking of the ARB, for me it also provided better braking.
All the other stuff(TiNi shock shafts, 2010 carbon, brass tray, mono ring shocks etc.) is included in the 2010 kit.
Then there are some small setup options like the 3 hole shock pistons, carbon lower rear shock mount and gear ratios.
The different ackermann inserts are supplied with the kit.
If you have a spare NT1 tank, diffs, belts, pivotballs or uprights you can keep those as those parts are a direct fit.
Can't comment yet on any weakpoints, but to me the car matches or even excels the quality of the NT1 so you won't need a lot of spares.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 09-29-2010, 02:07 PM   #469
td-civ's Avatar
Ok, great.
Hi Tuan,
ok good to know its the 2010 and i got it for $200 never been ran i will get the kevlar pulleys and the ARB after that ill see how i like it
i have nt1 2010, g4rs 09 and now the lab-c01 all will be running the same motor, pipe, servo's and radio
so we will se how it stands up
Old 09-29-2010, 03:15 PM   #470
Trader Rating: 24 (100%+)
Can i get some of that luck
RANDY SMOOTH is offline   Reply With Quote
Old 09-29-2010, 10:25 PM   #471
rocca30's Avatar
smooth if your going to the fort ill supply the tires.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 09-29-2010, 11:46 PM   #472
td-civ's Avatar
hey it must be you man lol it never happen till now lol
Old 09-30-2010, 10:29 AM   #473
okay that sounds good
Old 10-03-2010, 04:32 PM   #474
Today I did some testing at my hometrack. I decided to start with the same setup I ended with from the Apeldoorn track.
After the initial gearbox and engine tuning the car was already very fast with plenty of steering but still stable enough to put in consistent laptimes.
So I decided to use a new set of tyres and really test how fast the car was with the same setup from the other track. Within a couple of laps I was close to my personal best, and 0.3 tenths faster as the times I've been running lately with the NT1.
And this on a track which had low traction and a lot of leaves and dirt on the track.
After I burned through the first set of tires I put a second new set on the car and added one mm of caster. The car was again faster but tricky, but with some fine tuning I think I can get the rear more planted while leaving the caster as it is.
To give an indication about how good the car was, during our round of the nationals at the track, the fastest time was a 16.21, today I did a 16.23 on a track which had 5 other cars running.
I couldn't get the standard setup sheet to work, so I made my own.
I think it has everything you would want included, if someone has some improvements let me know.
Here the pdf and .doc version:
File Type: pdf Setup Sheet Capricorn LAB-C01_Blank.pdf (78.3 KB, 196 views)
File Type: doc Setup Sheet Capricorn LAB-C01_Blank.doc (89.5 KB, 197 views)
P1-RC.com
Old 10-03-2010, 04:34 PM   #475
Default Apeldoorn AMCA Setup
Here is the setup for the Apeldoorn Amca track.
Car was good, but still a little bit understeering, could have dialed this out with adding some caster.
Picture of the track:
P1-RC.com
Old 10-03-2010, 04:37 PM   #476
Default Mach Heemstede
And this is the setup for Mach Heemstede.
As you can see the setup is pretty much identical to the Amca setup, only added one mm of caster.
This pretty much proves to me that this really is a great car, because both tracks are pretty different handeling wise.
File Type: pdf Setup_Capricorn_LAB-C01_Mach-Practice1.pdf (113.7 KB, 209 views)
P1-RC.com
Old 10-03-2010, 05:10 PM   #477
bluer322's Avatar
Is the car sold anywerwe in the US, if so were.
T. Nicholson
Murnan Modified Motors
Matrix Tires
Serpent, 748tq
bluer322 is offline   Reply With Quote
Old 10-03-2010, 05:26 PM   #478
Team Epic is the US distributer, so you can get it directly off them or contact a hobby shop which is able to order at Team Epic.
http://www.teamepiconline.com/pages/...h=Capricorn+RC
P1-RC.com
Old 10-03-2010, 07:54 PM   #479
kamikazercracing.com sells kit
-vtec- is offline   Reply With Quote
Old 10-04-2010, 07:04 AM   #480
marsque's Avatar
Hi all,
Just finish building my kit. Just wondering, where can i get parts for it?
My location is Singapore. Anyone could help me???
the race is on!!!!
marsque is offline   Reply With Quote
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
